Can someone please help me to identify what year this is there in no tag with the ser # and it has a reman power head so there's no # on the block of
A '93 has a 1 piece cowling, not the clamshell that this one has.
A picture of the carbs will let us know if they are wmv or wmk. I think the wmv were used on early models, and didn't have idle mixture adjustments. Later models had adjustable idle mixtures.
Twactorman
its a very early 150 , i had one exactly the same for years , the guys that race merks love them because they are the best blocks to hot up so o am told .
BTW the gearbox is also rare so hopfully its not rusted in the splines ..
Stress points mine is a 200hp are the colors the same
Twactorman
Chris 1956 thank you the carbs are stamped WH 28 I will post pictures of the carbs later
Twactorman
Good job. I love it when boaters can look at a decal and know the exact year and model.
All this information is really helping me I so appreciate it guys, I'm determined to find out what year this is so I can find the right parts I need
Twactorman
Chris 1956 this motor sat for 9 years we rebuilt the carbs replaced the water pump and replaced the Thermostats and poppet valve, the motor is running and sounds very strong the problem we are having is we can't close the cowl with the choke plate cover on, we don't know if it's the right choke plate or not we tried 2 different ones
stresspoint
i could not honestly answer that ,possibly yes? the 200 was later , mine was defiantly a 150 .
as another poster said , the transom mountings changed ," from memory "this motor is the first with the updated transom bolt pattern that conformed with other manufactures and it had the trim assembly integrated.
OP ? does your motor have a red flywheel.
the prop and gear box are larger hub IE: same as Mercruiser stern drive.
i still have the gear box , flywheel cover and air box cover in the shed as i sold that motor as a parts motor and was left with some spares.
I'm a little vague on details as many motors have passed though my shop since then.
QBhoy
Want to put a wager on that?
Top stripe black, then brown, then orange then yellow
I likely would, if we were closer 😂. Definitely sticking with the used to be red at the top and used to be green at bottom…
Edit…all that was until I saw the other parts of the engine. I’d have lost money @Scott Danforth 😂
Once you find out the year of the powerhead, you can determine if the airbox is correct, and if the airbox is correct for the clamshell cowling.
Choke plates were d/c in newer models, The orginal V6 motors cane out in 1978, with choke plates. Not sure when they went the way of the Dodo.
stresspoint
i just found 67246 , whether that helps to get the correct cover .
OP , pm me if you cant find local and we may be able to organize to get this one to you.
jimmbo
The original production V6s were introduced in late summer 1975. The choke was replaced by the Enrichment system in the early 80s
Twactorman
Stress points
I don't have a red flywheel, would you mind posting a picture of your airbox I would like to compare from what I have
Twactorman
The power head is stamped 04 09 91 it's a rebuilt I'm assuming it's a 1991 power head that's the only numbers I found
Twactorman
The power head is stamped 04 09 91 it's a rebuilt I'm assuming it's a 1991 power head that's the only numbers I found I've tried 2 different air boxes and I can't close the cowl with either one of them they stick out to far, it's driving me crazy, could it be possible that's not the right co ??
