5.0 MPI Brass Sea Water Pump Bearings
Is it possible to replace the bearings in the brass sea water pump, or is a new pump the only option. They are getting noisy on my 2002 5.0 MPI.
Fun Times
Usually yes...Post your engine serial number and lets see if it's still original to the engine? It's a Bravo stern drive?
Fun Times
Yes, Bravo 3 stern drive. Engine serial # 0M327931.
So here is a breakdown of the impeller housing for your engine model, https://www.mercruiserparts.com/bam/subassembly/31747/7585/270
Found a kit that ought to work too new Merc part number 710-8M0140001, 'old number 8m0050018.
Search the part number online.
Have not taken one of that style apart but have rebuilt other style. If you have a press you should be able to replace the bearings
This is parts for ones I've rebuilt, cost was cheap. I found aftermarket bearings by searching on Merc numbers
Fun Times
Would you know if the newer part number has been updated in any advantageous way?
I know there is a big backlog delay at Mercruiser due to an IT security incident so getting parts is even harder to get then normal right now.
If the shaft is good then using the old number yields a bearing set found in the first 2 options here, https://www.ebay.com/sch/i.html?_nkw=8m0050018&_trksid=p2334524.m4084.l1313&_odkw=8M0140001
Or order everything individually or search out Hardin marine sea water pumps for an stainless steel upgrade. https://www.hardin-marine.com/c-116-water-pumps-accessories.aspx
