paoutdoorsman
Thread starter- Joined
- Dec 13, 2009
- 20
Is it possible to replace the bearings in the brass sea water pump, or is a new pump the only option. They are getting noisy on my 2002 5.0 MPI.
Usually yes...Post your engine serial number and lets see if it's still original to the engine? It's a Bravo stern drive?Is it possible to replace the bearings in the brass sea water pump, or is a new pump the only option. They are getting noisy on my 2002 5.0 MPI.
So here is a breakdown of the impeller housing for your engine model, https://www.mercruiserparts.com/bam/subassembly/31747/7585/270Yes, Bravo 3 stern drive. Engine serial # 0M327931.
nuwavemarine.com
I know there is a big backlog delay at Mercruiser due to an IT security incident so getting parts is even harder to get then normal right now.Would you know if the newer part number has been updated in any advantageous way?
