- Joined
- Jul 18, 2011
- 19,258
Greetings,
Branching off from my 'boat is being a boat' thread, I am posting about an issue with the starboard engine cooling system (Serial # in my signature below) Keep in mind that the engines in my boat are the in-house Mercury built engines, not the GM 6.2 that preceded them.
Fun Facts
Symptoms and efforts so far:
VesselView screen shots . . .
Stbd engine starts out higher in psi than the port engine
Stbd engine 'hits the wall' at about 2000 RPM and pressure does not rise thereafter.
After the high speed runs . . .
Diacom recording . . .
View attachment IMG_4921-a.mov
Looking for input, ideas, next steps.
I am thinking that there is a restriction somewhere before the sea water pump, which may explain why the psi starts out higher than the port engine, but then reaches a limit (14-18) psi. This has been the case on all of my 4-5 outings this year.
At cruising speeds (3500 ish RPM) there seems to be enough water flow to avoid any guardian issues. I'd like to see if I can resolve it, as it may only get worse, and probably cause more guardian mode when it is most inconvenient.
FWIW - on my previous boat, I did have a barnacle shell that lodged itself in the water intake at the bell housing. I'd hate to have it be the same thing.
I have a new impeller on order, just in case.
Here is a link to the Diacom recording file if any of the mechanics on the forum would like to take a look. https://drive.google.com/file/d/1DRqUjdCDcdxvhezkGRUdQvS_hv0NElaP/view?usp=drive_link
Fun Facts
- New impeller last year (about 30 hours on the impellers, they are spec'd for about 300 hours between replacement).
- Sea water strainers on both engines BEFORE the seawater pump.
- Bravo 3 outdrives with both side and nose cone water pickups
- SeaCore version of the 6.2, so full closed cooling.
- Raw water pressure is low on starboard engine at cruising speeds (spec is at least 20 psi at 4000 RPM)
- At low RPM both engines are within spec for raw water psi, and in fact the starboard engine reads higher than the port engine.
- As the RPM increases the port engine psi rises as it should; the starboard engine reaches 14-16 psi and goes no higher. See the screen shots of the raw water psi
- I cleaned out the sea water strainer on the starboard engine as it had some marine life debris in it. No difference.
- I sealed off the fitting for the fresh water flush, in case the valve was leaking air. No difference.
- I ran the boat at WOT for about 1 minute to see how the raw water psi and ECT reacted. the psi was port 24 psi, stbd 18 psi both at 5200 RPM. (Boat speed was 42 mph) port ECT was 171, stbd ECT was 178.
- I ran the engines up to about 4900 RPM for another 30 seconds or so, noting that the WOT run had gotten the stbd psi up a bit. (from about 14 to 18). After the short run @ 4900 RPM, the starboard engine went into guardian mode, based on exhaust temperature. (see vessel view warning message) 2000 RPM limit . . . I limped back to the mooring to go fetch my Diacom computer.
- No codes as per the Diacom. I ran about 4 minutes of recording at about 3600 RPM and noticed that the starboard side exhaust manifold temperature (Stbd EMCT) was about 25ËšF higher than the port side of the engine (Starboard engine for these) (see video)
