68 Offshore restoration
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Good progress. You going to put any rubber siding in your front floor hatch? That anchor looks like it will do a number on the alunimum/paint up there.
SHSU
Sharpie223
Not the final placement for the anchor, it really just ended up there to avoid any ER visits while kids played up front. (Hatch was down, covering it.) I'm not really sure where final placement will be, it might just be permanently stored in an anchor nest once I make one. Otherwise, I plan to cut some access doors between the footwells and the side storage in the bow (with proper radiusing and reinforcement). If I go that route, then I will make some leather "sheaths" for the points.
SHSU
That makes sense I would worry about my kids dropping it on my head as they "played"...lol... You have room to add the cool storage area. I didn't on my SS16.
SHSU
Sharpie223
Not much in the way of updates due to car repairs taking priority. I did decide my final direction for the gunnels. If I patch the holes, putty or weld, and then paint, the finish will never look right. So it's back to a covering. The budget has inflated a little more, so I went looking for eva or vinyl flooring. I didn't like the vinyl colors, and eva flooring was too thick. I then found some 3mm eva sheet foam. I'll use this and contact cement, probably just give it a putty patch just cause.
EVA sheet
SHSU
Same as you realized I would never be able to "hide" everything easily. That why I covered my gunnels too
SHSU
Sharpie223
Some progress.
Revised bow flooring is complete. Latches still needed. Then I sanded/countersunk/cleaned the gunnel holes and patched with putty.
Now I'm working on covering with EVA foam. There's some air bubbles, but I think I can fix that with more contact cement. It was a little sparse in areas. I'm not going to be too particular on this as long as it stays down. I might use this foam for the bow trim as well. Should stay cooler than vinyl and I can glue it straight to the sides.
And plexiglass for a new windshield is ordered!
SHSU
Good progress. Will have her back in the water by Summer.
SHSU
Sharpie223
Finished up the foam today. Had some more bubbles. I think my issue was not letting the contact cement dry enough, mixed with the foam being slightly oversized and under constant pressure. Redid those and I'll check them in the morning. It's not fantastic but better than a thousand holes. Once cleats, downriggers, and other things are attached it should stay down even better. While working on the bow I also came up with an idea to make a raised anchor caddy that I can also mount nav lights to, and possibly a spotlight and horn.
SHSU
Looks better then the original PVC board you were going to use.
SHSU
Sharpie223
A couple progress pictures. Reattached dash and working on instruments. I will mount a gps speedometer and somehow hardwire it (usb powered). I also have a digital tach to hardwire (battery operated). I'll probably go the easy route and find an automotive usb outlet rated to the correct voltages. I got the steering wheel on and then realized I forgot the cover for the dash mount. I plan to just leave it until such time that I find a nicer steering wheel, because everytime I remove it, another crack in the plastic forms. Then I started a cover for the top of the dash, where I've cut clearance holes due to raising the dash. It's plywood glued to carpet, I wanted to use eva foam, but didn't have a big enough section left over. I'll hit the wood with something to waterproof, then figure out how I'm going to attach with screws. Not shown, I marked some sections to cut out for a glove box and also footwell storage. I'll get to that next weekend.
SHSU
Any particular reason you want a speedometer? So many free gps apps on the phone or a Fishfinder with navigation will have it as well.
SHSU
Sharpie223
Fishfinder probably is fine, but I like everything at the dash, especially if it's sunny and I'm fighting glare, also just feels like a complete dash then. I've been using a phone app in test runs, but I don't have a mount and it isn't the safest.
Sharpie223
Not quite related to the boat. I found some clear, tintable enamel base made by krylon yesterday, and have been using it as a cheap medium for mixing mica and candy pigments for testing possible car colors. I am surprised by how well it flows to gloss, even after accidentally touching before it was cured, the fingerprints flowed back to gloss. I can't even find any orange peel and I know I sprayed some in. If anyone is looking to do an enamel paint job on their boat and don't like the typical colors, this might be good to use. Just have to buy mica powders and candy concentrate and play with colors.
Trying to make a nice deep metallic olive, but one that doesn't look "military"
Sharpie243
For some reason I can't sign in under the old account, forgot password never sends an email, and contact us leads to a failed webpage. So I made this account. Mods, if you're seeing this and the new account is a problem, can you find a way to fix the old one with password reset, otherwise this one works for me.
Anyway, I finished the windshield, wasn't careful enough and got a crack or two, should have cut larger clearance holes for tje mounting screws, time will tell if such screws were a mistake with thermal expansion as well. Also, careful of what plexiglass you buy, the material bought for my front windshields, while transparent, has lines/waves through it that obscure vision, we'll see how long I stick with these.
I added an anchor nest, not fully complete, and mounted the horn below it and spot lights to the sides. The nest still needs some uhmw guides and a roller, maybe this weekend. The glove box has been created, but I need to figure out how I want to hinge a plate for the door.
Otherwise, I'll call it officially splashed this last weekend. It ran pretty good, but trimmed out to far and got an overheat alarm, it then went into limp mode. I don't think there was any damage, but need to make sure.
Sharpie243
Did some engine testing, I decided to check the pulse count on each individual spark plug wire using a cheap digital tach. 8xx on top and middle, I'll assume cyl 1 and 2, 5xx on bottom or 3. At idle of course. This is a 1997 Suzuki dt75 ( carbed 2 stroke) and has cdi ignition with 3 pulsars around the flywheel. Does anyone with experience in cdi ignition know what would cause this? I'm working to get the flywheel off for better inspection, but have to make some special tools first. I also pulled each boot, all three made a change in sound but cyl 3 barely did.
Also changed the rectifier for the charging circuit, previously I was getting 6 volts at idle, now nothing. Is it just not supposed to produce anything at idle? I'll have to test underway I suppose.
Sharpie243
Some more testing today. I switched the #1 and #3 spark plugs on a hunch that maybe #3 was misfiring but still sending an EM signal to the digital tach. This time both cylinders had about the same speed (indicated, obviously they are going the same speed, the tach is reading spark pulses). When I removed each boot individually they both caused a change in engine sound. I wonder if something could just be acting up once hot? I also don't really trust my cheap digital tach. This engine has 3 pulsars and 3 coils, so it should just be reading as 1 spark per rev, but when I set it to that setting, it's showing 1700-1800 rpm, at idle, for an engine that should be somewhere between 900-1200. When I set it to 3 pulses per rev, it reads the 8xx rpm.
SHSU
Did you modify any of the stops on the engine or the PO? I din't trust my Tach originally and got a cheap digital laser tachometer to verify speeds. Helped me feel comfortable that my tach was reading correctly.
SHSU
