Brentathon
Thread starter- Joined
- Dec 29, 2009
- 399
Ayuh,..... 5, maybe 10 years life span, they usually fail at the manifold to riser joint,.....How long do these cast iron manifolds last?….
Geez.
This is saltwater cooled since 1991.
I guess ya just run them until they fail…
5 - 10 years??? I’ve owned this ‘91 boat since 1999, and that’s the original intake manifold. I also know someone who owned a 1991 wellctaft with the same engine, and there’s wasn’t rotted out, yet, in 2019 when they got rid of it.Ayuh,..... 5, maybe 10 years life span, they usually fail at the manifold to riser joint,.....
If you run 'em til they fail, odds are you'll be replacing the motor at the same time,....
Pitch the motor!
Yep… it’s a 1991; the long block was replaced in 2007 with a rebuilt, and that’s the original intake manifold. I don’t think they make this iron manifold anymore… “pre-vortec”, and I only have 1 inch clearance under the engine cover (i.e. deck), so I’m not sure if the vortec is a “high rise”, and whether it will fit.If you're referring only to the intake, I have one on my 4.3 which has been on it the whole time I've owned it in salt water in my use since 2002. Not flushed during the season ever, it is a moored boat so full of salt water from May-November every year. Still hasn't rotted through yet. But I do flush at the end of each season, drain and then back fill with a good PG antifreeze with corrosion inhibitors. I pull the stat housing and check the area right under the stat, that is where they fail if the cast iron gets weak there. Mine, is still solid but I do have a spare 4.3 intake in the garage.
If you're referring to exhaust manifolds and elbows, well, 7 years is about it.
Tap that area under the thermostat with a big screwdriver, if it's solid and no water in the oil, just run it.
From what I can see that area doesn't look bad but the rest of the engine looks like it's been having salt water sprayed on it from a leaky hose. Very important check all hose clamps and drain plugs make sure there are no raw water leaks.
I have heard of some engines rotting through in the water passage behind the exhaust valves and hydrolocking the motor, 1991 was a LONG time ago, if that engine doesn't have water in the oil that's gotta be some kind of record.
Maybe you were referring to exhaust manifolds. I was referencing intake manifolds.Ayuh,..... 5, maybe 10 years life span, they usually fail at the manifold to riser joint,.....
So…. I’m wondering if I should bother to replace the intake manifold…because it’s original since 1991.the cast intake manifold will last just as long as the head castings and the block casting in salt water.
right up to the point where one of them rusts thru to the crank case. the intake will rust thru near the water cross-over outlets
heads will rust thru near the exhaust valves
block will rust thru near top of cylinder walls
you can likely find a used fresh water one the dimesnsion listed for the marine edlebrock probably doesnt fit what you outline for heightYep… it’s a 1991; the long block was replaced in 2007 with a rebuilt, and that’s the original intake manifold. I don’t think they make this iron manifold anymore… “pre-vortec”, and I only have 1 inch clearance under the engine cover (i.e. deck), so I’m not sure if the vortec is a “high rise”, and whether it will fit.
But… I guess I’ll keep running it as long as it lasts.
These Chevy 350’s are amazing, how long they can last with saltwater running through them.
michiganmotorz.com
Having owned several I/Os over decades that were all saltwater used, rigorously fresh water flushing after every trip will increase block mortality to over ten years and maybe 4-6 years for risers and exhaust manifold. The risers are the first ones to crap out. I'd replace every 4 years and sleep well.Maybe you were referring to exhaust manifolds. I was referencing intake manifolds.
damaged engine rusted !!!!!!!!!!!! engine damaged !How long do these cast iron manifolds last?….
Geez.
I guess ya just run them until they fail….?View attachment 406225
