frustratedboater
- Joined
- Jul 10, 2007
- 477
Good evening,
I had posted some questions regarding a cracked pinion gear and have decided to purchase the gear set. New question: Attached is a list that shows shims for this engine on an on-line parts list for this particular engine. I will need to replace shim #7 that rides on the top of the pinion gear and not sure how I'm reading this (7.5, 7.6, 7.5...). I believe that the shim in the unit was destroyed and need to select a replacement. How do I go about selecting the correct one with a new gear set? Of course I'd appreciate your help with this.
My unit code is: 1SZF07373A
The gear set is: 57300-93841 (I believe)
Please let me know if any other info is needed.
