Water pressure valve replacement 2000 evinrude 4stroke
TnTommy
New to the boating world and have been trying to get this 2000 evinrude 50hp 4stroke/ Suzuki ready for the summer I’m trying to do any maintenance that should have been done boat sat for 3 years, it does run good took it out several times at end of last season. My question is the water pressure valve or poppet valve as it’s called by some is under the oil reservoir so I would have to take power head off to get to it, I’m sure it’s never been changed , should I change it or let it go unless I have a problem?
You are making a MISTAKE reading the parts diagram.-----The water pressure valve is NOT located where you think it is !
saltchuckmatt
Saltwater motor?
TnTommy
Where is it then? The manual says below oil reservoir?
Are you finding this in the SUZUKI manual for your motor ?----What manual are you using here?
Disregard my posts.---I have 3 of these motors for parts.----Might have to look at one sometime.
saltchuckmatt
No salt water been fresh water it’s whole life
I'd leave it alone and test. Run some mild soap or something. Impeller yes, stats? No.
I don't work on those motors but I've never seen a design where you don't have access to areas.
saltchuckmatt
So this should be the assembly, and where does this go on the block?
