dingbat
- Joined
- Nov 20, 2001
- 17,307
Not if it’s done right.All this electronic stuff in a wet marine environment just seems crazy.
Been building equipment for an environment that makes the marine environment look like a clean room for longer than I can remember.
Electrical component failures are few and far between. Most failures we are called into truobleshoot are customer induced. Bad power levels, reversed polarity, failure to put protective covers back in place, bent pins on connectors, damaged wiring, etc.
Easier to hit the button to monitor transmission performance in real time.Usually so you can discover a leak just before it's too late in my experience.![]()
Same with oil level/pressure
