No dipstick on 1989 era 3.0L?
dingbat
All this electronic stuff in a wet marine environment just seems crazy.
Not if it’s done right.
Been building equipment for an environment that makes the marine environment look like a clean room for longer than I can remember.
Electrical component failures are few and far between. Most failures we are called into truobleshoot are customer induced. Bad power levels, reversed polarity, failure to put protective covers back in place, bent pins on connectors, damaged wiring, etc.
Usually so you can discover a leak just before it's too late in my experience. :LOL:
Easier to hit the button to monitor transmission performance in real time.
Same with oil level/pressure
Tbf, not sure what the point of a transmission dipstick is. If I'm down there I'm changing the fluid anyway.
Maybe so, however a setup that requires 2 people to check and fill a transmission is stupid.
One under the vehicle with a pump and fluid, the other in the car,with the car in gear and running is a recipe for disaster. The mods to the trans pan cost 3x the price of a dipstick
nola mike
Car in gear and running? What?
Pmt133
That's all well and good if you have a TFT/Level sensor. Most I've seen don't. Fords oil pressure gauges are mostly an idiot light. :rolleyes:
My daily (not a Ford) doesn't burn oil. I check the level after an oil change and right before I am going to change it. There is a sensor that will illuminate a light if it gets low... though typically it's about too late if that happens. (usually failed cooler lines) Anything I routinely needed to check fluid levels on is quite old at this point in time so I get why it isn't a thing anymore. And the tech (when it's actually there) is convenient. The BMW self burps the cooling system with the electric pump when you change the coolant. That's very nice!
nola mike
It would be better if they started making coolant systems that didn't routinely self-destruct.
