1996 polaris sl 780 to much oil?
shelden
So I just got this ski a couple weeks ago and been going through it and checking the usual things. Fuel system ect. Finally felt good enough about things to fire it up and I feel like im getting an excessive amount of oil coming out of the back/exhaust. Granted its mostly just been idling with a few throttle blips hear or there but the plugs seem very wet and the front cylinder seemed to get alot hotter than the others so I stopped running it. Can someone tell me if this photo looks like a ridiculous amount of oil please? Starts up perfectly and idles fine.
Mc Tool
I suggest you google about SL780 front cyl running hot ......quite a bit of info there. Nothing that cant be sorted but you need to know.
As for the oil .....might depend on the brand ,and the possibility that someone has fiddled with the oiling in a misguided attempt to stop that front cylinder seizing due to lean burn issues ( read the google ) . I used to use castrol TTS @ 50:1 in my Kawasaki KDX250 and it dribbled black unburnt oil out of the muffler but fuel from the same can ran clean and dry in my chainsaws. I decided to be happy that the Kwaka was obviously getting plenty of oil and tried to forget about it .
shelden
Well from what I've been seeing the front cylinder runs hot on the hose. Took it to water today and it wasn't as hot so I think thats all set. Now im wondering if this is a good burn on my plugs or if its to lean.
Mc Tool
I would say a tad lean but its hard to tell from pix . They need to be a light tan (peanut butter ) colour and you need to look right up inside where the insulator contacts the metal body of the plug. . Does it still have the standard air box/filter ? After market performance filter assemblies usually require a bigger main jet because they are less restrictive.
shelden
Yes everything is bone stock. Can I just richen the carbs up a little with a simple adjustment?
Mc Tool
I doubt it ,probly have to replace main jets .
Get yourself a workshop manual and get into a jet ski web site .
I would also be using high octane gas ....at least untill your happy that fueling is ok
shelden
Why the high octane fuel? Just for a more predictable destination or are there other benefits?
Mc Tool
Two strokes run at their best when they are bordering on a lean mixture ....it only takes a change in ambient temperature or pressure then they can seize or get hot enough to pre-ignite , I just think that a high octane fuel gives you a little more protection if your pushing it a bit hard.
For a non race recreational motor I think you should run it slightly richer than optimal and most of these motors leave the factory running a safe rich mixture. Some peeps know this and lean them off a tad ....some go to far and martyr their motor.
2 strokes a fussy things and are surprisingly complicated for something with only 3 moving parts ( crankshaft , con rod and piston ).
Have a look at some KT100 cart racers ...they have a thermocouple under the spark plug with a digital display on the steering wheel that gives them a real time peek at the running temp and they will twiddle the carb jetting on the go ( they have carbs like chainsaws that have screw adjustable hi and low speed jets ).
If I were mine I would see what jets are in the carbs and unless you want every ounce of power I would stick with the factory jetting ....specially if you just want to ride the thing and are not interested in constant fiddling or stressing about swimming home.
Get in with a bunch of peeps who run these things ( maybe on line ) and if your interested there are butt loads of 2 stroke theory books which can give you an insight as to whats really going on . I have seen soooo many 2 stroke problems being misdiagnosed .......like if your running close to the edge tuning wise even stale gas can tip them over and you get a bunch of melted pistons .
I dont know your climate but if it has hot days ......try getting up early while its still cool and go for a blast ,it will run better in cool dense air ......most motors will, but it gives you some idea just how much ambient conditions can effect the tuning.
Oh and these 2 stroke jet ski motors are not the same as 2 stroke carbed outboards ......much more like a motorbike . 😄
