I planned on getting a dupe of what I'm taking off. I assume it's marine?? Look at the pic. although the back was open which I assume marine would be closed .CharlieReplace with a marine-rated circuit breaker. They should last longer in the marine environment and should be spark protected.
The pic in post 2 is a marine rated breaker and is used by VP, Merc and others. Can find them in a lot of placesI planned on getting a dupe of what I'm taking off. I assume it's marine?? Look at the pic. although the back was open which I assume marine would be closed .Charlie
Thanks but I dont see any labeling on either terminal.Which is which? I believe one cable comes from the battery switch based on my pic.One terminal is labeled line, one is labeled load.
