200 hp Johnson locking lever
pastorbud
I can’t seem to engage the lever to lock the outboard in the lifted position. (See video.)
I have a Frankenstein-motor. It’s a 200 hp Johnson. Powerhead model number J200VLSIF. Leg and lower unit off a dead FITCH, model E200FPXSSH.
It tilts up and down just fine. Just won’t lock. I’m not even sure how it’s supposed to work. First time using the motor since I put the units together and mounted it on an Aquasport 222 Sandpiper.
Gee, I doubt you will need that locking lever. If the PTT will hold the motor when running under load, it will hold it fine when not running.
You can use the flip down lock when trailering, if you think that is necessary, but I still think the PTT is up to it easily.
Crosbyman
2x4 works to :) _
info from the ETEC world.... post FICHT
dingbat
I never even knew it existed
pastorbud
Thanks! My other boat is an old Bayliner with a Force outboard that has a weak PTT. I use one of these Walmart specials.
