@muc please see attached the recording of my previous checks. Idle, then steady plane at 3000, 4000 and WOT
I looked at it but there is only about 6 minutes of data after engine reached completed warm up state and during that time and you were changing RPMs to much to allow the engine to stabilize. So not any real usable data. It never reached full PID!
When making a recording for diagnosis.
Run around until engine reaches complete warm up.
Now back to idle and then increase RPMs in 500 RPM increments holding steady at each for 5 minutes.
Really need to reach full PID to get numbers that are usable.
I did note that your trim usage was very unusual. I saw very little trim usage and did see it go into trailer mode? Maybe you have a problem with the trim sender?
During recording use the trim normally.
I hate to comment too much on this recording --- because garbage in garbage out --- but you had some misfire numbers I've never seen before.
And water pressure looks a little low.
I'll be very interested to see a good recording and see if they are still there. Maybe post a pic of your prop.
What I did see looked OK
injector on times, spark advance, fuel trim, fuel flow and MAP.
What's missing is O2 numbers.
But like I said garbage in garbage out.
