Thx Mc Tool....great explanation for a non mechanic like me. So if I understand correctly, any hose with an ID the same orifice as the brass restrictor should work? Would I be able then to get that size of hose to push onto the fuel pump nipple? It seems much larger?
I think I found where I can buy an OEM replacement hose but won't know until Tuesday. Thanks again for the help.
The hose will be a standard size ...like 4 or 6mm , the orifice ...as boscoe99 says is probly not really needed but I was holding off actually saying that
If that were mine and that brass orifice was "stuck in there " I would cut the rubber hose off it ... maybe give it a wizz in the wire wheel ( thread it on to a bit of wire to hold it ) to get all the glue ,rubber whatev off it ,grease it up and shove it into the new hose . Im just thinking that without that orifice the pulse might be strong enough to be a bit hard on the pump diaphragm and cause early failure .
As for Suzuki makeing it harder than need be ...I meant that glueing it in there ,not making the thing available . Tbh I would never consider buying that as a part ,how much would it cost as opposed to 50¢ worth of hose and re-use the orifice .
AND ....a manual ,either paper copy or pdf is the best money you could spend on your motor . I have been mechanic-ing for 45 years and I get manuals for everything . Having said that some are better than others , factory manuals are best .
