Questions about the set up of a Holley 4160 on a 4.3 V6
Lou C
Ok guys, my Quadrajet acted up again over the past 2 seasons, not running right, I had it all apart, tried to clean it the best I could, but no joy. So I took the Holley out of the garage that I tried a few years ago, the first time I tried it it wouldn't run right (loading up, too rich) so after re-doing the Quadrajet I took it apart, found a few things that didn't look right (loose clutch bolts on the rear metering plate) but never tried it again till now.
So I bolted it up, it runs surprisingly well, the primary mixture screws respond to adjustment as they should, but I can't get it to idle slower than about 670-700 rpm which I think is a bit too high for a dog clutch outdrive. I am wondering if maybe the secondary throttle adjustment screw (that little screw you can only see with the carb off) might need to be adjusted, but from what I can see from looking in the secondary barrels, the secondary throttle plate seems fully closed, I can see there is a small port below them and the transfer slot above them.
Any suggestions from the Holley guys (Scott?) I'd like to get it down to 600 rpm if possible.
You'll all laugh but I also have a brand new Edelbrock 1409 in case this doesn't work out as planned! But it is more work to install, I have to figure out the throttle linkage and I have to fab a bracket to move the big shifter bell crank mount that OMC used on the Cobras up and over about 1.5" for the wider Edelbrock with the side mounted fuel line to fit.
The Holley while some feel it can be more troublesome, is an easier conversion because OMC and Volvo started using this exact carb in 1990 after they quit building Quadrajets.
I have all the OEM parts to make it work (throttle cable mount, adapter, metal fuel line, etc).
Thoughts?
Lou C
Won’t fit on a 4.3 the front fuel line will hit the thermostat housing. The 4.3 used the side mount fuel inlet.
Flip the carb over. The secondary screw is underneath.
Make sure the transfer slots are both square on the revealed part
Once you get the slots squared up. You will need a vacuum gauge to set mix. Should be about 3/4-7/8 turn out
Lou C
The carb & manifold don’t have any vacuum ports so I have to use my dwell tachometer. I know about making the primary transfer slot square but the secondary is different because those slots are higher up. So should the secondary throttle plate be totally closed to get the idle lower, or opened the same amount as the primary? I recall reading this before….
jimmbo
When the Primary plates are in the correct location relative to the Transfer Slots, the Secondary Plate can be adjusted to attain the correct Idle Speed, a real PIA.
As for a Vacuum source. Does the Carb have a Choke Pulloff? If so, once the Choke is fully open, it doesn't rely on it, and it's source of Vacuum can be used
Get the primary transfer slot set square.
Since your 4160 secondary slots are up high, this is just a 2-screw idle mix carb. Get the secondaries just to they kiss fully closed
Use an unlit propane torch to set idle mix. You will just be waving the torch over the carb. If you add a bit of propane to the carb throat and idle increases, back out the screws 1/8 turn. If you add a bit of propane and the idle mix drops over 30 rpm, turn the screws in just a bit.
If you wave the propane over the throat and RPMs do not change much, you are as close as you can get without a vac gauge
Then adjust idle speed
Lou C
Yes it’s a pita but I guess that’s one difference between Holley & the QJet. So I’ll just keep at it till it’s right.
This carb doesn’t have a vacuum pull off it uses the old style vacuum piston inside the choke housing.
jimmbo
Both Carbs have their adjustability Issues. In the case of Holleys, they do sell a lot of Parts to make a lot of Recalibrations a bit easier.
With Q-Jets, a very large collection of scrap Carbs can yield some of the Parts
