1985 Bayliner 2750 Ciera Sunbridge Resto
eggs712
Here at the lake now, just logged the first hour on the new motor.
Everything appears to be working correctly thus far. Fast idle at 1800 is already a couple of knots faster than my old motor with the same prop (15×19R).
Since this motor came with an alarm wire, I went ahead and added a Garmin fuel flow meter, exhaust temp sensor, and engine room temp sensor instead of just pulling one wire.
I brought oil change stuff, so I get to cruise around and jam out for a while.
eggs712
Boat ran well... mostly. 20 hours on her now, going to do the second oil change when the rubber oil pan hose arrives (hopefully easier than changing through the dipstick).
WOT speed was 29.7mph at 5200 rpm with the 15×19 prop (target range 4400-4800), so a 15×21 prop is en route. The new motor has much better torque, and I jumped on plane in 5 seconds.
I did have an issue with the electric fuel pump, which I'm stuck with on this block. It's a rotary vane style that started heating up and not working after my fuel tank level went down after the first 8 hours; having the new fuel flow sensor sure made diagnosis easy. It was a PITA to change (would've been nearly impossible in swells), and the O'Reilly's replacement pump was a dud out of the box. After some reading, I decided to move the pump low in the bilge with only a foot of hose pulling from the gas tank. The original pump then worked for next ten hours without a hiccup.
redneck joe
i'm a bayliner fan had a few. Biggest was the 34 avanti. 13 foot beam, awesome pig of a boat.
eggs712
Oh awesome, I wish mine was a wider beam. When I get a big shop one day, I'll build myself a big steel hull.
eggs712
A 15×21 got me up to 37mph at WOT, but RPM at 5100 with no loss of hole shot. I tried a 16×23 today, with 35.5 mph WOT at 5000 and very little hole shot loss from a 15×19.
I suspect my tach is off, so I'll have to order a digital one before further testing.
In other news, the water heater was sometimes leaking rusty water, so I pulled it with no plans to replace it. I then finally tested my fresh water plumbing, and the old fittings leaked like crazy.
I pulled out all the polybutylene and replaced with PEX-A; no more leaks!
redneck joe
is it heated from the engine?
