Maybe my turn for new boat time
tpenfield
The pump action seems normal. I'm thinking your water pump is a pressure pump, as are many in boat domestic water systems. With the breaker on, the pump will go on to achieve a certain amount of pressure in the plumbing lines (usually 45 psi) and then stop.
If there is no water in the tank or if one of the fixtures is turned on, the pump will continue to run.
Agree
Think I found where the bolt goes
The bracket is there but don't see a bolt
