Discoloration on outboard
TnTommy
My 2000 Evinrude 50 hp 4 stroke has some white scale below the cowling is this because of heat and is it normal, anything take it off other than repainting it? I've had boat a couple seasons it was like this when I got it but seems to have gotten just a bit worse.
TnTommy
I haven't tried to remove it yet,I will try vinegar but it has never been in salt water
Crosbyman
odd... paint surface is not only soiled with some mineral it looks krinkled
as if overheated or gone through some weird stuff that only begins and stops at a clean junction of the lower exhaust housing. ????? .
what it used in some industrial application ?
if you do get the white stuff off..... it will not fix the krinkled paint. Paint job in sight !
When all done suggest you apply regular coats of automotive wax for added protection.
Mc Tool
almost looks like quite a bit of fuel ( or oil ) has maybe leaked out of the motor and run down the inside of the upper cowl then out down over the mid section and sat on the surface of the water , as there is some lesser damage to other parts of the motor....even the transom has similar markings .
