Re: WOT RPM's
Looks like there is also a bit of confusion here about the meaning of WOT.<br /><br />As the experts all know, WOT is not the maximum revs the motor will hit. WOT is a rev range or band, within which the motor will perform at its most efficient, which also means that it will last longer. <br /><br />If the manufacturer states that WOT is, say, 4,800 - 5,600, this means that your motor should be able to reach 5,600 suitably propped. If it can't, then even if you run at 4,800, your motor could be lugging. <br /><br />To run efficiently within the manufacturer's recommended WOT band, you also have to be able to hit the top end of that band. Once you've set your motor up to do that, you know that you can run anywhere within the WOT band at maximum efficiency.<br /><br />So even if you never run flat out, it's important to set your motor up so that it will hit maximum recommended revs. Most of us, like CA, can run at the top end, but prefer to ease off a little once we know that our motors are within the efficient operating range.
