vranasaurus
Thread starter- Joined
- Apr 18, 2005
- 105
The motor is a 1989 90 HP Evinrude.<br /><br />I finally solved my problem with it running higher RPM's(would only pull 4200 with hood on) with hood off(hood latch grounding out the coil). But now I have a new problem.<br /><br />I am only able to get 5400 RPM's no matter which prop I use. I have a 13 3/8" X 17 Stainless prop that I am able to get 5400 RPM's and 35-36 MPH(GPS). I bought a new 13 1/4" X 15 Stainless prop and now I get the same 5400 RPM's at 29-30 MPH. It makes no difference what load I have in the boat I can go by myself or have five guys in it. I should be able to get a lot more out of this set up. The boat itself is a 22' flat bottom aluminum jon boat that weighs about 700 lbs. <br /><br />Here's some info on the motor:<br /><br />I rebuilt the motor.<br /><br />Carbs rebuilt.<br /><br />Spark is excellent on all 4 cylinders.<br /><br />I had a mechanic link and sync the motor(After four days I decided $60 was a fair price).<br /><br />Fuel pump rebuilt.<br /><br />Fresh 87 Octane gas.<br /><br />Aside from this the motor has plenty of hole shot power and idles great. <br /><br />Per the experts on this board I am trying to get into the 5800-6000 range. But something has to be up. <br /><br />I am willing to try anything.
