New Stuff on Vehicles likes/dislikes
kd4pbs
That just had the default over drive engaged on the 4+3 no? The ZF6 had the skip shift I thought
Yes - you're right! That was the other C4 I owned. I forgot it was the '89 that was the skip-shift. Damn, I'm getting old when I forget minor details like that!
metalchewy
I got a 6 speed and it does get a bit indecisive in the twisty hills , I just paddle it down to 4th ( or whatev ) and unless the revs get to high (red line ) or low it stays there ............until I go back to D ........even if that takes untill the passenger seat unwanted information/ complaint /opinion thing reminds me :)
Sounds like a 6 speed auto if you have paddles. Do you have a clutch pedal?
The way skip shift works, I You're rolling into a light and downshift to first with the clutch in, if the light changes and you want to put it into second because you are rolling faster than first warrants, it locks you out of second and you can only shift to fourth gear.
Jeff J
If I were to buy a new diesel truck, the DEF system would disappear the same day the factory warranty expired.
Pmt133
Lol. All good. I have an 84 4+3 which is why I was curious. I know those changed every MY but was unaware of the skip shift. (Explains why!)
I'd wait through the emissions warranty.
alldodge
I deleted my 2008 but
"Currently" there are laws on the books which would keep you from ever selling it to anyone other than person to person, unless your willing to take the chance in court
Jeff J
The last I heard it was a $10,000 fine for a shop that was caught removing a DEF system. Might be kind of hard finding one to do it. I own a saws-all and a welder but the computer must be dealt with too.
Person to person sell nets more money anyway. Having the DEF system deleted would increase the value for such a sale. Just have to be willing to wait for a buyer.
I think newer 6 speed transmissions are very good.
Cough....cough....cough
Mine was rebuilt 3 times by GM. Google JMBX torque converter failures on the 6L80e/6L90e. You will find thousands of stories about failures
The torque converter failed, filling the transmission with glitter fairy dust
You can't remove 33% of a torque converter material, not do enough testing and not have issues associated with hydraulic deformation
The 8 speed that followed was worse and included a class action suit. The newer 10 speed is better, but is having issues and multiple TSB/recalls
The 4L60/4L60e was a much better transmission
cyclops222
A modern hydraulic transmission can do it all. And does it in the largest trucks.
Gear shifters are always unhappy. WAAAA WAAA Want more gear ratios. I will not stop complaining.
Mc Tool
Yes its an auto I think it may be a U160L , not sure now . Paddles are so slow that your better off just leaving it in D . Fits behind a 2GR-fe Toyota V6 FWD if that helps :)
As for the skip shift ......... why 🤯🤯🤯. That seems berserk to me . I wonder how many crashes or shat pants that causes .
Pmt133
The 10 speed GM uses is pretty good. The ford version (have both) is god awful.
The 6 speed is an odd occurrence because I've had early and late models (gmt900 and 2k) and you'd think they're completely different models.
The 4l60e sucks but I admittedly have never killed one. I've cooked a few 4l80s which blows people's minds when I tell them.
I have the 8 speed and its been the best driving slushbox transmission of all the GMs I've had. 10 speed included. Mine was post fluid update.
Mc Tool
10 speed auto seems to much unless the torque band is pitiful. When I 1st got the 6 speed I sorta thought that was to many but I do like it now . My other car 2003 Rav4 has only 3 speed and overdrive and it really needs a couple more . My old car was a 350 sbc with a powerglide (2 speed ) and that was a damn good tow car .....towed my boat and Hilly's van and his boat the last 50km to Te anau .......over the Blackmount hills
matt167
GM hasn’t had a solid automatic RWD trans since the TH400, 4L60E is garbage, 4L80E is less garbage. the 6 and 8 speeds are hot garbage with torque converter and a couple other issues. 10 speeds like to exchange reverse for an extra neutral. The Ford 10 speed comes from the same design as the GM but has a few different parts and the logic that is used is entirely different
jlh3rd
why is the 4L60E garbage?
Would like to know for preventative reasons.
When towing my pontoon, I use Tow Haul mode and sometimes with 3rd gear , not "D". Also have an external cooler that keeps my trans temps no higher than 170-180 F. , usually stays around 150 ish.
Fluid has been changed twice in 98,000 miles.
I don't use a heavy throttle, especially when towing.
^ + 1. coming from the GM tech.
the 10 speeds are a joint venture transmission with Ford and GM....Stalantis used the Aisin trans......Cummins Turbo diesel and Aisin 10-speed do not appear to have the same issues that Ford and GM are seeing.
Pmt133
I can't comment on a stock application th400 as... well... thats just way before my time at this point.
I've had three six speeds go out right around 60k and one holding on by a thread. The failure was always 6 neutrals but reverse worked. I didn't care to know the failure because its not my money nor my problem. (I'm not paid to work on the vehicle, I'll treat it as such since everyone else does too.) But based on that info seemed more like a valve body issue. If you mashed the throttle to redline in drive it would sometimes lock back into gear and drive normal.
The 10 speed in the ford likes to forget you put it in drive and sometimes move in reverse or just neutral drop itself randomly while driving. Most of the gear shifts it'll try and launch you through the windshield until it's warmish.
I'll also add to the garbage pile: 700r4. Yes more or less a 4l60 but still.
cyclops222
WE do know that a 10 speed is wasting time and acceleration.
9 shifts at 1/4 of a second each. is about 2 seconds of wasted time if you lift the throttle. Power shifting at WOT every gear shift.
Tow Truck come and get me.
My best thrill was new factory street racer. Brother new Plymouth with big wedge head and no heat, radio and some other things.
Brother said it was a dog for him. I asked to run it Sunday morning on Main Street.
Warmed up. 4500 let the clutch out with minimal wheel spin. Pedal to the floor. 2nd 3rd and then about 90 mph on main street. Doors opened. People looking around.
Good street car. (y)
Pmt133
I have the feeling that not many in this forum is very impressed by the cybertuck...
Cool concept. **** poor execution. Kind of like the Plaid. By the end of the drive I wanted nothing to do with it if that makes sense.
