Discoloration on outboard
TnTommy
My 2000 Evinrude 50 hp 4 stroke has some white scale below the cowling is this because of heat and is it normal, anything take it off other than repainting it? I've had boat a couple seasons it was like this when I got it but seems to have gotten just a bit worse.
TnTommy
I haven't tried to remove it yet,I will try vinegar but it has never been in salt water
Crosbyman
odd... paint surface is not only soiled with some mineral it looks krinkled
as if overheated or gone through some weird stuff that only begins and stops at a clean junction of the lower exhaust housing. ????? .
what it used in some industrial application ?
if you do get the white stuff off..... it will not fix the krinkled paint. Paint job in sight !
When all done suggest you apply regular coats of automotive wax for added protection.
Mc Tool
almost looks like quite a bit of fuel ( or oil ) has maybe leaked out of the motor and run down the inside of the upper cowl then out down over the mid section and sat on the surface of the water , as there is some lesser damage to other parts of the motor....even the transom has similar markings .
redneck joe
waters in tennessee are nice and neutral.
I'm voting that is had work done, with new paint, before you got it and age is getting to it.
TnTommy
Might be the paint cracking,but I cleaned it with vinger this morning and it did seem to help a little and it got the transom pretty clean so I'm gonna get some CLR and try to clean it. Probably will end up painting the whole thing this winter. Here is a pic of the vinger wipe down
saltchuckmatt
Industrial viniger is much stronger...(30percent) Than store stuff.
CLR is homeowner stuff and not very powerful. Looks like it worked good, the patch correct?
TnTommy
I actually wiped down everything in the picture
airshot
Both Clorox and Lysol make a mineral/ lime scale remover for the home. Does a great job removing rust, lime scale and mineral buildup. Not expensive so worth a try.
dingbat
Interesting pattern…you have more than just water spotting going on.
When is the last time you change the impeller?
TnTommy
Changed impeller 14 months ago one of the first things I did when I got the boat
tphoyt
Any chance of reaching out to previous owner to ask if the mid section and transom bracket were replaced? It’s very odd it’s only on those sections.
TnTommy
I did he said he had the boat 10years and he never had anything done to it. Kinda what I was wondering if it was getting to hot or something
redneck joe
ok if it was like that when he got it that still leaves a many year gap of info.
airshot
If that discolored area is plastic, that could be the problem as I have saw discolored plastic on many ocassions. If it is painted surface then heat or water in taking thin on the paint....in my opinion...
TnTommy
The piece at top with no white is plastic the discolored starts where the metal begins
