1986 Motor I did a compression check and one cylinder the upper starboard side had 60psi. I took the head off and the gasket was a mess and had a break in the metal ring on that cylinder. The cylinder walls look ok. I cleaned up the head and ordered a couple new gaskets. My plan is to replace the one I have off and if the compression goes back to normal I was going to replace the port side one too. My question is should I do that or not? I don’t want to fix it if its not broken but if the other side looks like the one on that I just pulled then I’m worried. The compression on the other side is 130 on both.
Thanks for any pointers on this.
