175 faststrike prop?
Ron G
Re: 175 faststrike prop?
Okay D went out tody hole shot better didnt shut down,but i coulnt get a good reading the speedo woulnt go over 60mph trimed all most all the way ran great kept bumping down on trim still 60 then finally went to dropping ,i guess i need to get a gps in the future,I was by mytself and the livewells empty :( Should i leave well enouggh alone? also do think i should take the hydofoils off?
Dhadley
Like John says, taking them off is free. Sure, why not? It will certianly give us a better understanding of how the combo works with and without it. You can always put it back on.<br /><br />Sounds like we found the spot that the water pump likes -- and doesnt like. They used to make scoops for the water intakes. Not much to look at but amazing little devices. Does your lower unit have the 4 holes for water intake or the slot?
Ron G
It has the slots,Ill pull the hydos off today,What kind of scoops and were do get them?do they bolt on over the intake holes?
Ron G
Here we go took hydroils off realy couldnt tell that much difference ran 65mph at 5500 rpm,ran smooth and was good made 6 runs all averaged that closly,partner got in boat on blast off motor died i guess it loaded up or something,heade off got about a 1/4 mile went to slow mode running 54mph?hole shot bad again.I dont understand itwhy would 1 person affecting this thing so much?with just me fairly good hole shot now and also it gets up and goingbymyself hits 55 mph quick at 4800 -4900 rpms but takes forever to get on to 5500rpms at 65mph,put some water in livewells takes forever to get up.Also motor died twice later in the evening and sputtered a few times while idealing ?,i was getting low on gas.
Dhadley
The scoop for that gearcase is part number 339247 I believe. The scoops for the holes arent available anymore.<br /><br />I was just looking at the pics again and I "McDonald'ed" (super sized) them. I noticed the location of the transducer. It may be an optical illusion but is it right in front of the motor? The lower unit needs to have a clear shot of the water coming off the transom for about a foot on each side of center. If its in that area lets pull it off the bracket and test again just for kicks.
Dhadley
Ron , when was the last time a water pump was installed? Do you remember which one? 5001594 or 5001595?
Ron G
I bought the boat last october i dont know when it was rplaced or even if it has ever been replaced.the trancuducer is about 10" from center of the motor.but the thing is the boat does fine with just me in it now no slow mode,do you think the water pump may be getting wore out??thanks
Dhadley
I would sure consider looking at it. Make sure to use the 5001595 kit. That'd be a great time to get the scoops too. Cant hurt.
Ron G
What are we talking about scoops?how hard is it to replace the water pump ive never done it before.
Ron G
When i redo the water pump,i was reading on another thread about a bullet nose cone of low water pickup is that a bolt on application or the lower foot replacement would it be better to put one of those on and were do i find them thanks D
Dhadley
If youre even considering a nosecone, send the gearcase to Bob's Machine. They'll get it on straight and it looks like a factory job. Because it is. As fast as your boat is you dont want to fool around with that not being on straight. And staying straight.
Ron G
Will do were is bobs machine?will i still need the scoops?any idea what one of those nose cones cost ballpark figure thanks.
Dhadley
The nosecone will have the water pick ups under the nose of the new bullet. The downside is that if you run in shallow water, youll suck up sand etc. The upside is you can jack the motor to the moon.<br /><br />Bobs is in Ruskin (south of Tampa) fla. Try www.bobsmachine.com.
Ron G
D i just got engaged so moneys going to be a little tight for the next year,i looked at bobs machine they do great work from what ive seen,im want one but not a possibilty right now i looked up the kit for the water pump but couldnt find it on iboats page,Im still confussed how another person or weight could affect as much as it is?Thanks
Ron G
put the hydroifoils back on got a little better holeshot still running 5600 with 2 people and full tank gas i think its going to be time to start on props,water pressure still good so over the winter ill put a new pump in for my own satisfaction,what do you think about props?Im thinking dropping to a 3 blade 26 or a 25 what ya think?or am i jumping the gun??
Dhadley
I have a 26 3 blade Michagin prop. I've been thinking about your set up and why it acts like it does. The 4 blade may have enough tail lift that its causing the water pressure isse with height. The other thing is that the small diameter may be working against us too. I've never been a fan of small diameter. It doesnt seem to carry well so that may explain the drop off in performance with an extra person.
Ron G
I was beggin to think the same thing that the 4 blade was an affect on it,i looked here at iboats at the 14 1/2 x26 ballistic and the 15 1/8 scorpion any preferences ive never heard of the scorpion but 15 1/8 would that be a little much?Im going to alabama this weekend and will look at some props at a shop there any ideas of llok for with diameter as a starting point.
Ron G
never thought about tail lift like that, makes sense now that you said a buddy tried out a 4 blade ballistic in place of his 3 blade and kept blowing out.I know why now, your knowlede is unsurpriseble thanks.
sangerwaker
Just to chime in my .02, stay away from the ballistics. Not worth the price you'd get for them in scrap metal IMHO. They tend to blow out easily and many repair shops (around here anyway) won't rebuild them. Excellent advice as always from Dhadley.
Ron G
amazing went out saturday had a tourny,boat ran better than it has since i got it jumped right out on plane ran great??why does cold air have that much effect it was foggy and id say around 60deg the way it ran i think we have the setup right for cold weather.do you think its just cold air or would more air to the motor also have the same results?
