Re: 1952 7.5hp Evinrude
Well Guys thanks for the good tips, I let her soak overnite with ATM oil and acetone mix, took a wood peg to one of the pistons two small taps and she was freed up cylinders look great, took carbon build up off the piston heads cleaned head and put her back together getting 70psi compression looks good to me. Took carb apart need a gasket cant find so will make one, lower unit dry as a bone but no gear damage looks like she might have been filled with grease . Plus it had about 2 miles of fishing string wraped around the shaft behind the prop, looks like the seal type bushing has taken a beation will try and locate parts not easy cant wait to get her humming got a big kick when I held the spark plug wire and turned the flywheel so she has juce.
