Re: 1965 Johnson Tri-Hull restore!
Got allot more done toning, but worked till 11:45pm.
Frame all painted except the front nose piece, since I have a bit of welding to do on it once I can turn it around.
Wheel's all painted, these rims were not in the best of shape, kinda rough but serve the purpose for now, just wanted to keep the spending to a min.
Supports all done, and painted. Got the cross hole drilled, first layed out the hole, then drilled through both sides with a 1/8" bit, then used a Uni-bit to bore the holes out, you get a much nicer perfect round hole that way, drill bit doesn't get a real nice hole.
