1965 Starcraft Holiday Restoration
Woodonglass
Re: {1965 Jupiter Restoration}
Pics Please!!!!!
PINIT
i will snap some when i get home from work in the morning, i did try and use a little bondo over a few areas to see how it would turn out but i couldn't get it smooth enough before breaking through again.
Woodonglass
Bondo is CRAP!!! Don't even Bother!!!! How DEEP are these Dings and Divots???
johnmorgan
really nice boat you got there, I also seen a fox mustang under a tarp. two awesome toys.
PINIT
Wood there not really deep its just wavy looking and i dont think it will look good painted.
PINIT
Thanks! Fox's are everywhere at my house, there is 5 total on the property. the one under the tarp there has been a project of mine for 3 years now. i dont know how im really into working on this boat and i cant get the motovation to fix up the car. maybe cause i drive this one. :D
Triton II
Just found your resto thread Pinit. Nice work, and FAASSSTTT! Good job mate! :)
TII
Piece715
Mine rails were full of hundreds of holes, dents, dings, and any other type mishap u can think of. I actually went with carpet. Used brown packing paper to make a template of the gunnel and then laid it on indoor/outdoor carpet and outlined the template. Used an ordinary pair of scissors to cut the carpet and had a local guy bind all the edges for about $90. Here is how mine turned out.. Used a web spray adhesive to stick it and holds well. Can't remember the name of the adhesive but im sure i have a pic of it somewhere... ill try to find it
Piece715
Here is just a couple more. I found the adhesive pic. Also did the inside walls of the hull. That is as much carpet as I wanted in the boat.
PINIT
well i got out the hammer and dolly and spent about two hours beating out dents. Still not happy with it. The carpet looks good but not really what i would like to put there. Wood that rubber is a great idea. im going to paint it for now and come back to this later. there kinda hard to see in the pics since there real shallow. more wavy then anything.
im getting ready to go get new wood for the floor. ( i had already bought some but the weather has ruined it) :facepalm: when i get it in what should i seal the floor with?
Woodonglass
What kind of wood R U using? Make SURE it's NOT PT!!!
PINIT
PT would be? treated wood? i made it about halfway to lowes and the fuel pump went out in my truck. :( got it home and took the car back to the auto parts store. after $200 worth of parts im not happy. well im going to Twin Peaks and treating my self to a cold one.
PINIT
going to test fit the transom and start drilling the holes in it, figured it would be easier to vacuum out the wood shavings with the floor still out.
Woodonglass
PT it Pressure treated Plywood and the chemicals in it will EAT your boat and I'm NOT kidding.!!!! Hey, I was in Big Lots yesterday and they have a 4 x 8 piece of 1/4" foam mat that looks like diamond plate flooring. If you cut it into strips for your gunwales it might look really good.
MichaelP
The gunwales are looking like they could use some Marine Tex or JB filler. That PT is a NO NO on out tinnies. That baby is coming along nicely.
PINIT
I have seen that foam mat before, im thinking i will go with something like that, im going to just paint them for now so i can keep rolling. i just picked up some exterior plywood. what should i seal it with?
Triton II
... i just picked up some exterior plywood. what should i seal it with?
Pinit, most guys here use Epoxy to seal plywood, but keep in mind it's affected by UV so once sealed you'll have to use a varnish or paint to stop the UV rays destroying your hard work.
TII
Woodonglass
Two choices, Epoxy or Resin and Mat. Nothing available locally in the quantities you need.
www.uscomposites.com You'll need a couple of gallons and if you use Poly and Mat you'll need 6 yds of CSM mat.
PINIT
got the first two parts of the floor in, the transom test fitted, needs a little sanding. i have to go pick up some more floatation this week sometime. Most likely go with resin and mat to seal it the floor. my father in law owns an auto salvage and he can order that stuff in big amounts.
