1965 Starcraft Holiday Restoration
PINIT
Re: {1965 Jupiter Restoration}
Well i picked up everything i need to start painting. im guessing i should paint at day break when its coolest outside??
Woodonglass
Yep, and wear a bandana on your head. Don't want any water dripping on the paint!!!! ASK me how I know THAT!!!!!
PINIT
Oh no :eek:! Thanks for the tip Wood. Hopefully i won't have to work much this week and get it painted. Not likely though, the A/C business is booming during the summer.
PINIT
would it be okay to shoot the clean metal primer over the etching primer,? i have some uneven areas of old paint. the etching primer is not thick enough. if so would i have to add hardener to the clean metal primer. Thanks.
ezmobee
Absolutely. The etching primer is supposed to be light. If you want any real fill/masking you need to use the clean metal primer.
Woodonglass
Yeah, I'd recommend TWO coats of the Clean Metal Primer and do a light sanding between coats with a Scotch Brite pad. That will give you a GOOD base for the final coat of paint AND even things up a bit. I would then do a Wet Sanding with 320 grit and final wipe down with Mineral Spirits right before applying the first Color Coat.
PINIT
Thanks Guys! I got the bunks back on the trailer today, will be wiring it up and putting new lights on it tomorrow. also got the first coat of the resin on the transom. i have a huge pile of paint/ chemicals and parts in my bedroom just waiting to be used, i now have everything to complete it, HOPEFULLY!!... im having to use all my party money on this thing. :D
Woodonglass
Transom looks really NICE!!! What lake do you frequent? When I get "Blue Flamingo" done I will be going to Skiatook. Maybe we can meet up one day??
PINIT
SKIATOOK!! all the time. Tall Cheif Cove is 5 min from my house. :D and yeah! it would be so cool to see these old boats together. i get thumbs up and complements all the time when i take the boat there.
Woodonglass
Well then Some time In August it's for sure gunna happen!!!!
PINIT
Cool !! Anyone no where i can get the inserts or something that will work for the two drains that go through the transom in the splashwell area?
Woodonglass
West Marine Carries them 42nd and Sheridan. East side of the street.
Woodonglass
I been eyeballin that for a couple of months. A bit toooooo pricey for me!!!
kfa4303
Banned
Niiiiiiiiiiiice!!!! Nothing like a wooden boat. The old OMC looks right at home on her too.
PINIT
yeah it does seem a bit steep on price, not running. Maybe one day.:D
PINIT
kind of a shame you cant see this thing. its turning out great..
Woodonglass
WOW! Looks Like a GYM Floor!!!!
PINIT
Doesn't it!. The epoxy i used says its U/V protected up to 120 degrees. you think it would be fine to leave unpainted?
PINIT
Finished up all the primer and sanding, will be putting first coat of Semi gloss white on the bottom early Tuesday morning. Most likely go with 3 coats, and then for the color....well my girlfriend cannot decide between royal blue or sunrise red, im thinking red :D
