1968 Holiday Restoration w/pics
Azlo
Re: 1968 Holiday Restoration w/pics
Ok this makes more sense. Not only is the fuel pump in circuit with oil psi switch but the pump is also hooked to the starter solenoid. I got this from the link that GLG fishing posted.
"ABYC standards require that the electric fuel pump turn off if the engine dies and the ignition switch is still turned on. It is common to power the fuel pump by the starter solenoid "I" terminal during cranking, then the pump is powered thru an oil pressure switch when the engine is running. If the pump runs all the time the ignition switch is turned on, you are asking for trouble. Just think, the engine dies from rich running because the needle and seat in the carb is stuck open. The ignition switch is left on for a bit and the pump fills the carb, intake etc.. with fuel. You go to resart and kaboom!!!!"
Makes more sense now that the starting solenoid is in play.
Last Mohican
Ah Ha. There is the answer. I knew there had to be something to it. That also means you can not switch the ground with the oil pressure switch.
Re: Starting 1968 Holiday Restoration w/pics
I think I have place in Austin Tx, that may have a used engine for this 120hp. Thats where I got mine. Great little eng.$$$ But worth it.
Charlie
Azlo
Charlie
Thanks for the tip, I will make a note of it.
:confused:
GLG fishing
Like I said I?m not 100% sure how to hook up that dang thing.
That oil pressure safety switch a roo a relay thingee ba jig :facepalm:
Just know you need one.:)
Projects looking good man.
GLG
Azlo
So went ahead and sand my sides to get them ready for zinc. I figured I try the yellow zinc this time.
Then fill scratches with primer. Didnt straighten some dents, i kow they will be back.
But I am not putting the aluminum trim back just yet. I will try to polish them after splash some time. However im having some thought as to how everything will fit together. Keep in mind I have moved the dash a foot forward. So i know there will some creativity.
Azlo
Alzo YouTube those vids man
It takes a while to edit this videos, but now Im getting the hang of it, heres another.
Goerge Lucas Productions?,,,,,,,I dont think so, more like Jose's Lucas Productions :cool:
dozerII
Good job azlo, both the video and the paint job.
glen
starcrafter65
I was gonna ask at one point - what does the boat look like.....looks sweet!
Hey 1968 Holiday I/O brother......did you convert to electronic ignition? I am thinking about it......
Also - you are gonna soon have the same problem I now have........you finished your boat and there is nothing left to work on!?!!
Azlo
glen
Thanks Glen, its looking good right. I hope I make it this year man.
The points got tuned so well that im gonna wait for them to wear out aand install the electronic ignition. I know theres a big debate on the subject but when isnt there. U know starcrafter65, i might experiment with like putting a fuel injected engine like I saw the guy from australia did here in I boats. Hmmm I also need a roof on my tin so theres something for me, dont have to do it but its there. Or theres fishing.:D
KellyC
Hey Azlo, where did you get your self etching primer? I am not finding a lot around here other than the rattel cans.
Awesome job on the paint, photos and video as I liked them all.
Azlo
U know I have the same problems and rattle cans are expensive. But in this case i just bought the 1 quart rustoleum filler primer & just sprayed it after the zinc. Will see how it holds. :confused:
rpontius77
Hey guys. If you go to your local automotive paint supply dealer, you will find all the self etching primer you need. Most carry it in pint, quart, and gallon sizes with all the reducer and hardener you need with a mixing chart. Hope this helps.
lakelover
I used Pettit 6455 Metal Primer - it's the green ZC primer, good above or below the water line:
Had to order it online, do a google search.
Bighoss
This thread is too cool man. Azlo, great work... I'll be tuned in daily to see this story finished. How about a clinic video for painting....please!
sprintst
Awesome video man. You cut it exactly right to catch the highlights.
kilowatts
Hi Guys:
You can do my video anytime Azlo, great thread and it's gonna be a great boat. I envy the warm Texas weather where you'll spend loads of time on the boat with the "Bling" engine.
kilowatts
Azlo
I couldnt find any rustoleum etch primer but in rattles cans. How much was that? How it work for you?
Thanks Big hoss, yeah im ancious for the finish too. I mean it so close but ill post a vid of splash bro. Stay tuned.
whew man the learning curve was there ill tell u that. But it was kind of boring just the vid with out the effects u know. Like a mature marriage ,,, u got to spice it up baby.
Hi Guys:
kilowatts
You envy the texas weather?! hehe if u notice bro i dont were shoes in the summer time. I wet the floors and turn the fans on. right now its 105 in there! But in a sense your right, it would give an excuse to go boating. U know ur right!
lakelover
It was around $40/qt.
A qt. will cover 100-150 sq. ft. Needs to be used within 8 hours of mixing, I mixed a half-batch. Seems to have worked fine, no issues.
Huron Angler
Love the vids Azlo, great editing work like as sprint mentioned ^^.
Entertaining and educational, KRS would call it edutainment.:D
Taping stripes is a real challenge, and a good example goes a long way.
