1973 SRV 220 OV Resto
mrdjflores
Re: 1973 SRV 220 OV Resto
well, with my back out, didn't do a thing on the boat yesterday. last time my back went out like this, i was in the sanding phase on the hull, so i could at least lay on my back and sand....but now, i can't even climb up the ladder to get in the boat.
need to get over this back dilemma pretty quick, i'm in full boat mode right now and dont wanna stop
mrdjflores
did manage to place an order with uscomposites today...just enough stuff to do the transom for right now
GT1000000
I know someone who, in few days will be looking out for the delivery truck...:rolleyes:
Take care of your back, can't get much done with an aching back...
mrdjflores
yeah...this sucks!!!
my neighbor helped me a bit today, and i think we have deteremined that i can get the transom in there as one piece.
so just 2 layers of 3/4" ply, instead of 3 layers of 1/2"
GT1000000
Even better, much less work and hassle...hope it pans out
mrdjflores
plan for tomorrow, maybe, is to make cardboard transom template and see if a full layer can be installed...
weather and health permitting that is
Woodonglass
mrdjflores,
I'd recommend lamming your transom using Titebond III. I will NEVER delam. The glue has some of the Highest ratings in the industry for Waterproofing, strength, etc... Then coat it all with resin and then a layer of CSM. Drill some 1" holes in the entire assembly and then PB it to the outer skin. The 1" holes allow the PB to squeeze thru and give you a mechanical bond as well as a chemical bond with the PB. Fillet it, then apply two full layers of 1708 and finish it off with a final layer of CSM. It will be there 50 years from now with proper maintenance and care. The first link in my signature has drawings and details. Just my 2?. Take care of your back!!! The boat will be there when you heal.;)
mrdjflores
if using 2 full layers of 3/4 ply...here was my thinking..originally..
1) coat each layer with resin
2) laminate the 2 layers together with CSM in between them
3) bond the laminated transom to the inside of the hull with PB, using notched trowel
4) 2-3 layers of CSM on the inside (side you can see from inside the boat) of the wood transom
5) full length tabbing of the wood transom to the rest of the hull in between each of the final 2-3 layers of CSM from step 4.
am i way off base here??? i like the idea of TiteBond III between the 2 layers of the ply, instead of a layer of CSM...will the rest of my idea be okay???
was hoping to do all this this weekend, but again, i didn't order any 1708...just the 1-1/2oz CSM
mrdjflores
to be on the safe side...i just got off the phone with uscomposites and added some 1708, extra resin...and of course....rollers (i completely forgot about them)
mrdjflores
well...back is feeling better...enough to take SWMBO out for a date, and then a midnight romp in the pool....
tomorrow, weather permitting, do some cleanup from the demo going on in the boat and make a template for the transom (crossing fingers that i can do the transom in one piece)
mrdjflores
well...maybe i spoke too soon about my back.....uugghhhh
mrdjflores
feeling better, through modern chemistry....
worked about 30 minutes diggin wood off the transom...sweated out about 5 gallons....110 degree heat index....yuck...
maybe i'll go fishing in the shade instead
mrdjflores
i ordered 2 different types of rollers...what ever the guy at uscomposites said i needed....one style for resin and one for rolling out the glass
Woodonglass
Yep the one for rolling out the glass is what I call a Bubble Roller. I use the 6" rollers from HD for rolling the resin after I scrape em down with a hack saw blade to De-Fuzz em.;)
mrdjflores
well...according to UPS...all my goodies should show up today...yayyy!!!!...
so i will be working hard this week to get the transom ready..
will get some currrent pics up here tonight
Woodonglass
Be looking for the pics. Take it easy and don't over do with that back. Careful of the heat too!!!
Cptkid570
Ensign
I just did some catching up on your thread and wanted to comment about your rear seat(U-shaped seat) vs a sundeck with a straight seat. My opinion: Go with the U-seat, but make it so that you have an extra pad that you can use to fill in the "U" and then you have a large bed back there if you fill in the U. Kind of like if you have a table in the middle of the U that sites real low with a pad on it. Don't know if that made any sense or not. But, great work on the boat.
Do you think the boat will weigh more or less when you are all done?
mrdjflores
yeah, i've been thinking of the idea of a center padded section that would turn it into a huge bed.....dirty thoughts, dirty thoughts.....but i have to come up with someplace to store it when not in use.
As far as weight goes, i don't think i'll be much heavier...about the only extra weight i'll be adding is a second full width 3/4 plywood layer for the transom, and some extra support for the seats...plus the weight difference between a ford 302 and 351w
