Re: 1975 Starcraft 140 Evinrude OB -- project
Snake oil huh GT? Ok, note made.
Hey Jsoutside and rrumba, Pink snow flake turtle neck sweater, hmmm. I might have one of those in the closet.
Have not been able to wear long sleeves let alone sweaters for years now. Hot flashes you know? LMAO. You think working in one of those make shift blue tents gets hot when it is 90 degrees outside? Try having hot flashes while under there. Yep, I am loving this 50 degree weather here in MS. The heat I can handle, the humidity kills.
Totally had forgotten about the cooler find. Wow that is when you know you are living life right. I was thinking of having an areas to place a cooler or 2 inside the seat that would go across the back of the boat. I am going to be using 1 cooler as a live well and the other for life support!
my old boat had the tank removed, but still not really sure where it was unless it was along the side. When I got it there was a portable tank which I will probably go back to using. I am thinking gas tank on one side of bilge area and batteries on the other. That is the way it was so why not.
As far as the orange peel, splatter some red on there and the fish will just think it is food. You won't even need bait, just toss the hook overboard and they are on. Hmmm, perhaps there is something in that. I am gonna go patent that idea. Number to come....
Thanks for the info rrumba, I am gonna go check out Jasoutside's thread a bit. I love to look at other possibilities. The only problem with research on here is I get so involved that I end up on here for hours and getting nothing done. Where does the time go
I think iboats needs a bigger server, keeps telling me it is busy. I think what it means is: don't wanna hear from a woman
