tullydf
Thread starter- Joined
- Sep 3, 2012
- 65
I have a 1976 Ted Williams 15HP s/n(217-587610) outboard that my Dad purchased new from Sears. It had sat for years and years in his garage, Since 1978. Last year I started to work on it. It started after a few pulls and I actually used it. It ran a little rough, but not too bad. This year, I rebuilt the carb and it is a beast. My main concern was that there was little water coming from the engine and I was worried of over heating it.
I decided to drop the lower unit to replace the impeller. When I removed the inspection plate to disconnect the shift rod, I noticed the shift rod on the lower unit was corroded. Upon removing the bolt, the rod crumbled at the top where the two rods met. The upper link is fine, but the lower shot.
Today, I proceeded to remove the lower unit. It did not want to come apart on the leading side. I tried everything. Ultimately, I had to resort to excessive force and as a result, the fin broke in several places.
I found a lower unit housing with a good shift rod for a 1976 Wizard 9.9 (supposedly made by Eska also Model: ESK6610
a7) on ebay.
To me it seems that the vintage of 15 hp motor I have is exact to the same vintage 9.9 engines. I would assume only carburation is different.
The lower unit looks exact in every way. I am hoping to take the guts from mine and transfer to the other housing.
Does anyone if this will be compatible?
Also, are the 15hp and 9.9hp of my vintage virtually alike?
Any help greatly appreciated!
Dave
a7) on ebay.
Dave
