- Joined
- Oct 25, 2011
- 25,311
Re: 1979 Imperial
I bought my wood for the build! Sweet!
I went with 4 sheets Araucoply 3/4" for transom, bulkheads and stringers, and 3 sheets 1/2" Araucoply for decks, and other vertical framework. The decks will have one layer 1.5 oz CSM on the bottoms, and at least two layers of 1.5 oz CSM, and I'm considering a single layer of woven also????? Would this give the 1/2" deck some additional strength? How about 1708? Just 1 CSM topside before installation. I don't want to give you bad advice, so not going to give tabbing to the hull, CSM & 1708 order but yes, 1708 on the deck & some for tabbing. Once deck is done for strength, use CSM to cover 1708's texture, weave or waffle pattern. And a build primer may fill remaining waffle some too.
And my sheet of cdx 3/4" I'll use for my work table was warped big-time! So I'm laying it on 6 - 2x2's with various batteries topside in hopes of straightening it out.... Flip ply & rotate weights as necessary.
Next is to place my order for glassin supplies! Hurry up taxman! Double Yep & Great to hear....
You'll need to frame it anyway, but quickly:
