Re: 1979 Imperial
10-4 on the hairy PB to fill in the void. Thanks for the advice bro-
I managed to remove additional material from the bow gunnels. I dig the height their at, and the gained space will allow better access while building the bulkheads and deck stringers. I still have some trimming on the side consoles, but the bow it's starting to look how I envision things.
I also removed the rear seating area in preparation of aft deck construction. It really opened things up! I'm now able to day-dream about deck storage, the bilge area, starting battery, and fuel tank location.
I'll be removing all the foam from the main deck to the transom (painted grey), and under the splash well...
I did notice some water in my bilge that was previously dry... It appears the center stringer has de-laminated and water drained out when I moved the boat to dollies. My solution is to expand the small bilge area forward ~ 1.0' removal of this small deck area will let me inspect the stringers condition, as it's not possible with the cap on. Either way I like the idea of a slightly larger bilge area.
pics are at the end of stringer from the bilge looking forward.
