Re: 1982 Sylvan Bassboat project
Now you know I am going to be watching this process real carefully...
I take it you have read "oops!" suggestions on foaming? Here is a link...
http://forums.iboats.com/boat-resto...sion-progress-pics-234392-15.html#post3205843
Laying down some PVC pipes to act as drainage channels, along with plastic sheeting down in the cavity before pouring the foam...Placing your false deck down, pouring the foam, remove the deck, pull out the foam "plug", take out the PVC pipe, reinstall the "plug"...so on and so on...at least that is my plan...
I personally think that two layers of plastic sheeting are a cheap safety net to hopefully prevent any leakage due to perforation and permanent bonding between the hull and false deck...also, make sure if you use the PVC pipe, to plug both ends with duct tape or rags...BECAUSE...that expanding foam is STRONG! when it starts to expand...it can easily lift several hundred pounds, so if the false deck isn't securely fastened, and being that its only 1/4", very well braced, it will Blow and Bow, even before the stuff starts to expand out of the vent holes...
Let me finish off by saying...THANKS! for being the guinea pig
...I can't wait till I get to this point...
Happy Thursday, bro!
