1984 Silverton 34C Remodel/Update/Upgrade PIC HEAVY
25thmustang
Re: 1984 Silverton 34C Remodel/Update/Upgrade PIC HEAVY
Al's had a hiccup with the hull polishing. Used buff magic and it worked well. I read the directions wrong on the pro polish and it looked like garbage. My father spent part of his vacation re buff magicing the hull, and last night we polished it up. It came out fairly nice for a 28 year old boat.
And a side by side before and after on the topside.
Also plan to polish and add a clear that works in the water to the exhaust ports.
ezmobee
Hull looks great, although that pin stripe isn't up to your usual standards ;)
NSBCraig
One of my projects is the same boat.
Were working on making sure it'll run out to the gulfstream and back to fish, instead of all that pretty work your doing. Which looks great!
Needed to rebuild both motors and the complete fuel system, but it's running good now. Not fast 22 knots top end and 16 cruise.
Keep up the good work, I'm diggin the photos.
25thmustang
Ezmobee, that pinstripe was out on next years to do list.
A bit of motor work has been done. Found out the risers and manifolds are in great shape and it was a worn impeller causing a bit of warm temps during survey.
JBF 1962
Great thread and awesome work, been making some notes, is that Epifanes uv resistant? it looks amazing!
25thmustang
The Epifanes is UV resistant. The CPES acts to block moisture. Between the two I hope the teak stays nice looking for a while.
25thmustang
More wood ready to go back on the boat.
ezmobee
Well that looks amazing!
BSnB
Absolutely stunning woodwork and the finish on the hull is amazing too. When you can read fine print in the reflection, you've done well.
How in the world were you able to keep cat hair out of the wet varnish, mustang, or paw prints for that matter???
chriscraft254
Great work man, I love me some shiny teak,lol Truly looks amazing, be careful when wet.:eek:
I still think teak makes a boat a boat. Seriously looks fantastic,keep up the good work. The stainless looks great also. might have to get me some buff magic just for the stainless, not giving up my Triple XXX woody wax. :)
Friscoboater
I just read through this whole thread. You are doing and awesome job, and I just love that big boat. I am ready to see her splashed.
25thmustang
Long Day today.
This is where it started a few weeks/months back.
Then got it sanded and scrubbed a couple of weeks ago.
Then today was bottom paint.
Then line up the bottom paint and boot stripe.
25thmustang
Then it was time to lay some paint.
Liking the look with the polished exhaust port.
chriscraft254
Looks fantastic man! I like that color to. the hull is really shiny and just clean looking now. You must be proud! Awesome.:)
25thmustang
Thanks, the Buff Magic is actually really good stuff. We still have to hit the green with pro polish, and then finish the topsides. All in due time.
BSnB
Looks great Mustang. Did you clear coat that exhaust port with anything?
What bottom paint did you use?
25thmustang
It will be cleared with an anti fouling clear coat. We will see how it holds up. The bottom paint was Interlux Ultra Kote. Got it for less than 1/4 cost.
BSnB
Great deal on the Ultra Kote! They recommend VC-17 around here, but I know I've got something else on the bottom presently. I'm concerned that the VC-17 won't stick and I don't have time this year to take it down to bare fiberglass. Next year. What you used looks like what's on mine. I guess I'll ask the yard if they know what will stick. Someone I talked to said "Bottom Kote" will stick to anything. Maybe Ultra Kote will too.
25thmustang
For the price the paint couldn't be beat. We are fresh water so no barnacles to deal with. If it fails, it may get a soda blast and redo next year.
BSnB
I'm fresh water too. Lake Michigan mostly, but my slip is off the river and we get some scum and slim and growth. I'm intrigued by this idea of soda blasting. I've looking into it here too. I've planned on trying to sand the bottom down myself and then apply an epoxy barrier coat. I dread the time and effort of sanding that whole bottom, but the prices I've seen to soda blast were pretty steep.
