1984 Silverton 34C Remodel/Update/Upgrade PIC HEAVY
lil buggy
Re: 1984 Silverton 34C Remodel/Update/Upgrade PIC HEAVY
Great news,,,,, not sure what a cutlas bearing does tho.
Carpet looks great, it's all coming together:) you've made great improvements this year,,,,, congrats bud
25thmustang
The cutlass bearing is in the strut, where the shaft rides through. If its worn it can cause issues. Glad it's all set and the prop and shaft were in good shape.
lil buggy
Thanks for the explanation, great that you got her takin care of quickly:)
25thmustang
Boats on the hard, so progress continues. FYI since this photo we added two additional stands.
Use Black Friday to grab cheap side chairs and pillows. They dont match the couch, but look good and are very lightweight which helps out a lot for when you need to get into the bilge.
Also working on the stateroom door. As with the head door the center sections were laminate and needed to be wood. I had some luan I bought years and years ago and decided to give it a shot. So far it is almost ready on one side, and will be flipped and the back side done.
F14CRAZY
Ensign
wow that's luan? It would be sweet if the 1/4'' stuff they sell at Lowes/Home Depot for floor underlayment was nice enough to finish like that
jbcurt00
1 out of 2 sheets of luan at 84Lumber here is that nice, on 1 side. About 1 in 5 pretty good 2 sides. But it takes some digging to find nice 2 sided sheets.
The blue & the orange big box stores here sell patchwork quilts (patches) of potato chip shaped luan or an underlayment that has gridlines in both dimensions to help w/ nailing/stapling it down, so not real good for finish work, stain & varnish...
LorenHaus
Electric head and holding tank are in. Toilets mounted on a mahogany platform due to the height difference. It's fresh water fed and will get two vent lines in and out. The head is close, just needs the laminate cut for the walls and some additional trim.
I just picked up the same Jabsco head for my Silverton and was thinking of making a riser for my head too. Howd you bolt your riser to the floor?I can think of a few different ways but it seems the best would be to screw up and in from under the floor.
25thmustang
I have no idea where this luan came from. I got it from a friend for $5 a sheet. It's tough finding both sides to be presentable. Hopefully I can make it work from the two sheets I have.
The riser is through bolted in the center, then the head through bolted onto the riser. It's very firm in place and the right height.
25thmustang
Some more.
Redid the filler panel in the salon.
Also put the bungs into the head trim. One step to finalizing the work in there.
thatguy
Spectacular work Mustang!!!
I will be following the thread closely, as I have alot of the same work to perform on my new boat (and old F-32 Trojan) My old girl needs some fiberglass work to be performed prior to all the pretty stuff. I picked mine knowing that I was going to need to repair the Trojan wet bridge deck.
I couldnt pass the deal on the F-32
tom
thatguy
tom
lil buggy
Glad to see ya back at it, hope you had an epic summer on her. Looking forward to the step by step on both doors, the Luan is looking great.
25thmustang
Thanks, the doors work is slow and time consuming with waiting for it to dry. But I will post up as I work.
Thatguy, the F32 is a great choice. Very similar layout to my 34. Yours should be full of nice wood in the cabin already!
25thmustang
Another couple of coats.
Then some testing of sanding and buffing.
BSnB
Beautiful work, as usual, 25thmustang! Seeing the work progressing on yours make me wish my boat were closer. I've really got to find storage closer to home.
lil buggy
^^^ agreed. that woods really taking a shine to you:D as always! I'm loving the pics
25thmustang
Thanks. This winter the boat is only 15 minutes from home, verse over 45 last year. Makes stopping in a lot easier.
I'm a fan if taking of lot of photos when working. Even of the most boring stuff. Also helps if/when the day comes to sell. You can show the work you put into it and potential buyers usually appreciate that.
25thmustang
Boring update.
Sanded with a palm sander and 220. Still needs more poly to make it perfectly smooth. A little nerve racking power sanding into your finished wood, but its the only way to keep getting it flat and smooth.
Then wiped it clean.
Then loaded another layer of ploy on top of the sanded finish.
This piece has a lot of really nice gold color popping through. Hard to imagine that terrible looking luan can stain and look like it does.
sprintst
Beautiful work. Must be hard to leave once you get in there :)
25thmustang
The best part is with all the amenities of home, you don't have to leave. Heat, air, fridge, head, shower, tv... It's like a small apartment!
