1985 150hp trim piston removal
gerber
hi,
i have the main trim piston out i managed to remove the top spanner seal bolt and have the shaft on the bench.
how do i remove the ends on the main piston shaft to replace the small top shaft seal???
thanks dave
gerber
Re: 1985 150hp trim piston removal
a photo, i know my explanation might sound confusing.
the seal i need to replace is sort of dangling in the middle of the shaft.
thanks again if you can help. dave
gerber
Re: 1985 150hp blackmax trim piston removal
Come on guys ,
surely someone recognizes this main cylinder piston for a trim unit. I cant be the first,
it is an 85' after all, do i have a unique one???
d.
Droll
Keep the assembly in the vice, see picture...top piece are a special bolt, you might be able to use the same tools as used when you removed the whole assembly.
BEWARE !! steel balls and springs under the "bolt", not any hight tension but beware .
attachment.php
attachment.php
This might help ....
Arne Kjetil
gerber
fantastic thank you!!
hey what does the 4, 5, 45,5 etc mean??
thank ,dave
gerber
ok, i have it back installed.
Is there a procedure for filling this unit and bleeding it??
thank you, dave
