Piece715
- Joined
- Jan 26, 2009
- 757
Re: 1985 E50BELCOB Outboard 50 hp - Unidentified wire and found retaining Trunnion
I haven't tested it yet.... The tan wire was cut and then split into two... half of it goes to where the pink arrow is and where that butt connector in black is feeds into the dual "rogue" wire (half to the spliced tan wire and half to the ground... the other end of the wire was just hanging free) Not sure if that made sense....
Ok and I just went out and tried to test fire the motor. When pumping the bulb there is a gas leak in the engine. I know where the leak is but not sure if that should be doing that (guessing not) and not sure how to fix it. We had the motor running for about 10 sec before it died.. Started again and prob 5-8 sec run and can't get it started again. Im guessing where that leak is happening is putting too much air into the system. Take a look at the vid and see if this is something i can fix.
Yes thats definitely a ground.....as you already pointed out, question is why? Where does the rogue wire go before it reaches that grounding stud? Directly to it via nothing else?
The tan wire has 12v when the ign is on.....the sensor grounds that wire if overheat is detected.....this activates the overheat horn. Have you tested the horn now with that rogue wire out of the system?
