Hmmm. Should be a washer on the inside of the plastic cam follower (next to the carb body). Is that in place?
No - how thick is that washer.
As the others have said, the washer is at least a good 16th of an inch thick and the inside diameter only fits over the threaded portion of the shoulder screw. It wouldn't fit over the main portion of the screw. As far as the adjustment screw, these instructions are from the manual for my 84 so hopefully they will work for your 86.
Advance the throttle until the mark on the cam lines up with the center of the roller. You can see a dab of white paint on mine in the first picture. The throttle shaft should just begin to move at this point. The manual suggests to put a "throttle amplifier" on the shaft to make the movement easier to see as in the second picture.
At this point you back off the adjusting screw until the throttle is completely closed, then turn in the screw until the throttle shaft just begins to rotate.
The 3rd picture is what mine looks like at wide open throttle.
believe that's it (again, with main emphasis on the cam follower screw).
