1986 ss 201
Status
Not open for further replies.
dozerII
Re: 1986 ss 201
Dozer, you're in good company.....5/8 is the compromise the factory made on both of my boats. drove me nuts til i figured it out. along with their dang 5/32 reevits....
B2, nice thing about 5/32 reevits they are real easy to make 3/16!!
Man, about time the sun came out. You must need more boat cash by now. And I bet the wife is happy to see you off to work in the morning. :rolleyes:
Hey GA, ya it is good to be back to work, I'm sure the Admiral is happy about it to.
Glen
tigger3650
Re: 1986 ss 201
Not much to show, the rain has quit here after 10 weeks, so we are playing catch up at work, did get some motor parts ordered though.
Hey Tigger, I use 5/8 ply for the floors, I like how it adds considerable strength with out the weight of 3/4. I use G1S fir ply with three to four coats of Spar varnish. The floor in the 201 was 3, 12' sheets of 1/2 in run front to back, they were attached on the rib ends and the two stringers.
Glen
Dozer,
I can't get 12' sheets here. I a thinking about 5/8" sealed w/ the Spar varnish (or equivlent). I would run an 8' piece from the consoles back and then a 4' to the stern. Rough measurements looked to be about 25" wide. Does this sound right? I am really hoping they are 24". If not I might expand the stingers so that 24" will work on the outsides and jsut cut the center pieces wider to make up for it. What are your thoughts?
Mike
jbcurt00
Re: 1986 ss 201
Dozer,
Mike
Tigger,
Doesn't 8' piece from the consoles back & then 4' to the stern give ya a double layer at the transom & none at the bow?:facepalm: Unless your SS is a rare double stern boat......:confused:
Do you have a thread started on your project? Pix there will help get ya some answers to the many questions that will come up. Esp w. the tin crowd, they are drawn to new threads like a weight-challenged kid is drawn to free cake:rolleyes:
dozerII
Re: 1986 ss 201
Dozer,
Mike
Hey Mike what are you working on? Do you have a thread started? Lets see your project.
tigger3650
Re: 1986 ss 201
Tigger,
OK, someones math is off, hopefully not mine. Currently there is 1 piece 12' long that runs fr the console all the way back to the stern. Since i cant get a single 12' piece I was going to start from the console with an 8' piece and then a 4' piece from where that one ends to the stern (8+4=12 right?). I heard the bridge to get to my boat should be open this week so hopefully I can start on it this weekend. Once I get to it I will start posting some pictures here and starting a new thread. Working on a tight budget so I am trying to use Dozer's project to gather as much stuff as I can before actually downing the boat.
tigger3650
Re: 1986 ss 201
I found some 5/8" Marine ply for about $65 a sheet. I have to drive into downtown Jacksonville to get is but hopefully this week I will get an early day at work to run up there.
-Dozer, can you tell me what the width of your pieces are and if i can make it work with 24" on the port and starboard sides? That would save me quite a bit of wasted material.
I am also thinking of using PVC trim boards from Lowes as backers for the bolsters in the bow and along the top of the gunwales, I just need to figure out how to get the vinyl attached to them.
Mike
barato2
Re: 1986 ss 201
that's a great price on marine ply. i was paying abt $75/sheet for 1/2". grab it while you can.
Nautolex adhesive will work for the vinyl. really, Liquid Nails type stuff would probably do the job....not structural or below water line
tigger3650
Re: 1986 ss 201
I heard the bridge is now open!! Hopefully I can get out of work in time to go get it. Now, for the weekend, work on the boat or take it out on the water?!?!?
FishNmemories
Re: 1986 ss 201
Glad to hear the rain has stopped and you're back to work Glen. Its dried up around here pretty fast too...my Gal has a honey-do-list that I'm whittlin my way through...
Rusty
dozerII
Re: 1986 ss 201
Hey Rusty, ya it stopped raining, so now we are whinning about the heat, typical. Real busy at work, but holidays are coming quick and 2 weeks at the lake is looking good.
Should have some photos of the little bit of progress and the two boxes of parts that came in soon.
tigger3650
Re: 1986 ss 201
Finally got to her. Here are some pictures and I will let you all know when I start a new thread. IMG_20120713_193528.jpgIMG_20120713_193546.jpgIMG_20120713_193556.jpgIMG_20120713_193610.jpgIMG_20120713_193640.jpg
dozerII
Re: 1986 ss 201
Okay finally just a little bit of progress. While I was cleaning up the exhaust componets this is what I found!!
So that is a couple hundred bucks of the budget going the wrong way.
I got all the exhaust parts cleaned up and painted including the new manifold,
when I pulled the motor, only one exhaust shutter was in the y pipe, after I got the y pipe off the transom sheild I probed around looking for the other shutter, no luck. Then when I went to paint it look what fell out. I think this the reason the ports side was real warm and the starboard side cold when I ran the motor.
And the pile of parts waiting to be installed.
dozerII
Re: 1986 ss 201
The only other thing I got done was the access holes for the motor mount bolts.
and the motor mounts cleaned up ans painted ready to install
jbcurt00
Re: 1986 ss 201
Looks great, 'cept having to make the new manifold purchase......
jasoutside
Re: 1986 ss 201
I feel like a big slacker. All I did was wash my Merc down :redface:
Nice Glen:)
tigger3650
Re: 1986 ss 201
Not 100% sure. I think the title said 206VS. When I Googled it, the only thing that came up was the boat you are redoing and other than the color they looked identical.
CheapboatKev
Re: 1986 ss 201
Are you going to put the shutters back in?
I think I wouldnt, just have to be carefull to not come to a full stop after haulin arse so your wake doesnt came back into the motor
Status
