Well, ignore my previous post. After looking closer, those are there on both assemblies.
I ordered a new grommet for the water tube. Better safe than sorry.
There are the bottom aluminum bolts with the anode that have a square head. There is a rubber washer that I cannot find anywhere online. There is however a rubber washer between the anode and the bolt. Where can i get the rbber washer that seals the transom off?
Painted the ski locker with the 3rd coat and wax. I don't know if I will sand it to smooth it out more and then paint again. Maybe I'll leave it and throw a rubber mat down there. Nobody will see it anyways. I added the off white to it so the dirt doesn't stick out too much. Otherwise it would be bright white.
test fitted the assembly which took longer than I thought. The holes I drilled were 1/8 off. I drilled them,straight but i noticed when I took it apart that even from the factory they botched the job and drilled again a little offset. Well I did the same. Put it back the way it was they say.:facepalm:
The new panel for the gauges is not exactly how I thought it would go. Unfortunately the bend is sloping a little and therefor will screw with my new panel. I measured it in one spot but off course, nothing on boats is square. Eventually I want to make a fiberglass panel in the future. This one is temporary to get by.
the test glue with 3m 4000uv Was somewhat good. It stuck and needed twisting to get off but not as strong as gorrila epoxy. So i will be using the epoxy glue. Maybe another test could be pl premium glue.
