Boomersoonerva
Thread starter- Joined
- Nov 27, 2022
- 25
You where the one that said look at the crank seal and I replied what I did
I changedTry the coil, then try pumping the primer ball when it's starts to die.....different tank, then report back.
You might possibly try this.
i swapped coils and it did not follow. So I thing I’m going to replace the power pack.Try the coil, then try pumping the primer ball when it's starts to die.....different tank, then report back.
No I did not move the wire. Pulling the fly wheel nowCheck for damaged wires coming from under the flywheel....could have a short
When you swapped coils did you also move the coil wire?
The wire could be the problem.No I did not move the wire. Pulling the fly wheel now
Wires look good the only thing I noticed black stuff onThe wire could be the problem.
Stator plateWires look good the only thing I noticed black stuff on
Looks can be deceiving.Wires look good the only thing I noticed black stuff on
I did then it wouldn’t start at all, switched back and back to the same issueLooks can be deceiving.
My wife looks good but doesn’t work.
Swap the wires and see if the problem follows.
Take picture of under the flywheel. Plug wires looks my good means nothing.Stator plate
Funny! My uncle always said, "the woman's place is in the home, right after she gets off work?"Looks can be deceiving.
Yes, thank you.soul
I already took it apart, the black wire I cut by accident removing the shielding of the wires. The original #2 looked pretty new before I moved it to #1 position.Take picture of under the flywheel. Plug wires looks my good means nothing.
Try to eliminate one thing at a time correctly.
Well your in it now. Go online and seek out testing all those components and then you should have this tool to put everything back on so they are set right in relation to the flywheel.I already took it apart, the black wire I cut by accident removing the shielding of the wires. The original #2 looked pretty new before I moved it to #1 position.
Also also checked the leaf valves and they looked good and pretty new.
ThanksWell your in it now. Go online and seek out testing all those components and then you should have this tool to put everything back on so they are set right in relation to the flywheel.
Look and see if any of those components have wear marks where they might have rubbed on the flywheel.
