steely85
Thread starter- Joined
- Apr 18, 2015
- 121
My cabosil and more resin should come in the mail tomorrow, so I will be buzzing down the rest of the stringers with my belt sander to make sure everything is level side to side and cutting and grinding the lip of the deck off.
Then tuesday I believe I will make the rest of my fillets to transition the 1708 better to the hull. I will also cap the wood stringers with peanut butter and rid the tops of any voids. I think that would make the glass lay smoother without any bubbles.
It is kind of funny that my outer stringers are only 3" high on the outside and my 1708 strips are 6" and 12". Looks like I'll be trimming those down anyways. Another idea I had was if I lay a 4" piece of tabbing, then I capped my stringer with 2 layers one 10" and one 12". That way I would go from one side over the top to the other side and tab everything to the hull, or would that be a waste of fiberglass. I could just use one 10" and one 12 inch piece and just leave out the 4" tab. What do you guys think?
