Wanted to give just a little update...I TOTALLLLLLLY Scored today!! All along with this project I really wanted to replace the back to back seating at the helm for a nice captains chair with a bolster seat.
The problem is that are so darn expensive...I don't care if you buy it new or on Ebay..they are a couple hundred dollars all day long. So, I was kind of reserving to the fact that I'd probable have to put my original seats back in and try and make a bolster of some kind.
Well on a whim I called this Monterey dealer on the other side of town and asked if they ever have used captains seats from a project boat, or salvage boat or whatever. He said as a matter of fact I think we have one right now...and its an OEM Monterey seat. Then I asked him how much he wanted for it.....$45 bucks!!!! I said, I'll be there in the morning, hold it for me. So, I picked it up today...not a rip or tear anywhere and it has the mounting bracket with forward and back adjustments....I'm totally stoked! So, now I want to make a box I can mount the pedestal to, rather then bolting through the deck...Got any ideas!!!
Since you already have most of the floor up, why not go with a factory look and reinforce the floor from underneath to support a pedestal mount. I think you will be much happier with the look versus a platform or box. Looks like you might be able to get to the underside of the floor via the ski locker. I would also look closely at the deck where you want to mount the seat. Some manufacturers reinforce this area by default since they are not sure if the boat will end up with a pedestal or back to back seat. All you really need to do is slide a 3/4" sheet of PT plywood with some glue of some sort on it, in the general area were the base will mount up. Then run some screws through the floor area to hold it in place, just seal it up well.
Have you already put the floor in? You could glass an aluminum plate to the underside, drill and top for bolts. Much less chance of the bolts pulling loose and leaking as screws would. If the floor is down and you have access, but I'll assume you don't past the stringer, use some bondo and set the aluminum into place. just make shure you rough up one side with the grinder. Aluminum is a much better backing than ply as it will not compress.
Mtribe, you could gelcoat the deck which would make it alot tougher, You could brush it on then dab the flat side of a foam brush in it to make it nonskid. Worked great for my swimplatforms.
I'll look for that thread.
Gel-coat would be cool for your deck!
I want to do the driver seat like you if I ever do mine and have priced them.Glad you found a deal.What you have done looks great and if I need to do mine I will look here when I do it.Glad you posted this up.
MTribe08,
Looks like you are making some very good progress.
Nice work
Bob
