1999 bayliner vibration
ntbtech
I have a 1999 bayliner 4.3 alp1 gen 2, vibrates turning left and right and trimming up or down, has new u-joint, shaft and gimbal bearing, need some ideas.
Ayuh,...... Welcome Aboard,....... In the water,..??
What kinda shape is the prop in,..??
Rick Stephens
I saw a sealed u-joint in a new truck that had no grease in it. I have seen a few u-joints missing a couple needles. When in doubt, suspect even new u-joints.
Did the alignment get checked when the work was done on the drive shaft?
ntbtech
new prop, just checked alignment, it is off can not tip engine enough for tool to slide easy. previous own had engine out to replace a mount, then he burnt up gimbal bearing. then i bought it, new joints new shaft new gimbal, ran smooth for about hour, started vibration. have slight scoring on new shaft at gimbal.
Rick Stephens
Don't run it until alignment is perfect. May need to pull engine to make sure all the mount parts are present in place and/or not damaged. Also check transom and stringers for dry rot - which should be called wet rot. Take a drill and mark it with tape so it goes in no further than 1 1/4". Drill an inch or so away from the lowest keyhole bolt in the transom and drill near and below the motor mounts. Anything except light colored wood may be the cause of the problem. You can easily fill the holes with 3M 5200 which can come in small to large tubes.
Scott06
In additon to what Rick mentioned check the gimbal bearing is fully seated and turn freely, If it is scoring the shaft it may have not been fully seated or damaged by not pressing on the outer race to seat it, or the alignment is horribly off
ntbtech
bearing is seated, used bushing driver to seat, port side mount the bolt looks to be going in at a angle.
Scott06
Port side bolt for mount into transom plate or into stringer? If its the lag into the stringer that isnt a big deal but wouldnt surprise me if you have issues with the rear mounts either sagging or missing parts.
Rick Stephens
Note, a gimbal bearing driver is relieved so it only impacts the carrier, not the bearing. The bearing is taller than the carrier and using a tool that is not relieved will destroy the smooth surfaces inside the bearing itself.
ntbtech
bushing drive had a lip on it, port side rear mount bolt is at a angle, all parts are there but looks cooked. when you first install aligning tool it kicks a little to left to start and goes in tight. up and down makes no difference. going to install new mounts, coupler, and gimbal tomorrow.
Scott06
Make sure to check the transom for rot while you are in there, otherwise all the other work and elbow grease could be for nothing
ntbtech
thanks for all the advise everyone, will let you know what happens. i think it is in the rear mounts, replacing coupler because i am there
Need to stick with this thread instead of starting another. Your new thread is in the FAQ section and no one can reply. Stick with this thread
Post a pic of your rear mounts
If the rear mounts were replaced with new style then you might not use the spring washers. If not then are the spring washers in place?
ntbtech
engine still out of alignment, new rear mount, front mount had already been replaced, new gimbal bearing, installed with new bearing tool. front of engine will not go low enough. original bearing failed to the point shaft had to replaced.
can i shim rear mounts?
No
Post a pic of the rear mounts
Does the alignment bar go into the coupler at all, and if so how far?
If it doesn't go in, where does it touch (top, bottom, side)?
Can the fiber washer be moved?
ntbtech
going to work on it in a little while, will post pics then, fibers appear to be glued.
ntbtech
when gimbal bearing got hot could it have damaged the housing and not be visible?
