While adding a circuit breaker (it had none) to my trolling motor today, I was checking various things and came across two things I have questions about:
One, while doing a continuity check on the hot circuit, I got a reading of 0.01 with the multimeter set on "20k", which I'm not certain what this means. Is this acceptable? I had to use a long lead due to the locations of the ends, but the lead isolated gave a reading of 0.00.
Out of curiosity, I then tested the ground at the foot control and got a reading of 1, which, since the motor runs, can't be right. I am not certain I was testing at the right terminal, tried them all, including one marked "common". Is it possible that the foot control is by-passed by the ground, and the ground goes straight to the motor itself?
I did the searches and came up with nothing.
Thanks,
Thanks,
