2nd Try at first boat...Opinions
ezmobee
Re: 2nd Try at first boat...Opinions
By they way, the chris craft was my friend's boat and apparently he just sold it.
ezmobee
Not sure. He did say he got about $1500 more than what he had into it. He bought it off ebay without really knowing anything about boats so it was quite a learning experience. He's looking to get a jet boat that's lighter to tow with his Wrangler.
Burgh_fisher
Nothing like making a profit and gaining experience. hope i get that fortunate!
Burgh_fisher
guy was listing to much on site it kept flagging him. But i was fortunate enough to get the number and a ton of info. Guy takes a lot of pride in the work he has put into the boat. Spent 45 min talking to him going over everything. Will post the info he provided and pics any advice will be greatly appreciated.
Burgh_fisher
18.5ft 1989 Sea Ray Bowrider 180 with 135hp outboard. $4,800
For Sale: Boat, Trailer, Ski's, Tube, Life Jackets, etc. Details Below
Boat has been fixed up and updated and has a clean title on the boat
and trailer
Fiberglass Hull (Seats 6 people)
135hp Mercury V-6 Outboard with Stainless Steel Prop (Quicksilver
Mirage 48 13700 A41 19P)
Open Bow
Trailer - Dual Axle Aluminum I-Beam trailer with working lights (NEW
marine winch, NEW flex coil wiring plug, NEW trailer hitch nose)
Details:
1. Floor Repaired
- New Marine Plywood Decking with a layer of new fiberglass
- Newly framed in gas tank area (Treated lumber with fiberglass and
marine plywood decking supported by an extruded aluminum square tube
grid)
- New dense Marine foam replacing the old foam in the empty spaces
under the floor decking)
- New 28oz Plush marine carpeting (tan)
- Newly framed in ski storage area (stainless steel fasteners,
treated lumber, marine plywood, fiberglass)
- Newly framed in Bilge area
2. New Seats
- New White Captains Chair (driver seat) with Swivel base
- New White ******** Premium Lounge Boat Seat (********* #74660)
3. New Stereo and Speakers
- Sony DSX-MS60 AM/FM/Satellite/iPod Docking Marine Receiver
(Flip-down, detachable faceplate with 2-line LCD display and AUX
input. Includes Remote Control) (********* #92230)
- Two Rubicon 6-1/2" 125 In-Boat Speakers, 90 watts RMS, 180 watts
Peak (********* #13943)
4. New Navigation lights (front bow red/green), rear pole light with
new harness
5. New Bilge Pump - Rule 2000 (2,000 gallon per minute automatic
computerized bilge pump) When turned on, it checks for water every
2.5 minutes. Shuts off automatically when no water is present.
6. New cigarette lighter outlet for externals
7. New Marine Ship-2-Shore radio with 8ft fiberglass antenna
8. New Fish finder (dual beam)
9. Two Marine Batteries with switch and voltage meter to tell you how
much charge the batteries have
10. New boat cover (purchased February 2012)
11. Gas tank - Aluminum with NEW 3/8" hose/bulb and inline gas filter
(with a spare).
12. Steering - Hydraulic power steering (with NEW installed TELEFLEX
Outboard Cylinder Hydraulic Seal Kit)
13. Life Jackets - 6
14. 2 pairs of water ski's (Ski pylon is currently not installed, but
the mounting hardware for the pylon and the pylon itself are in
storage. The pylon braces will need to be modified to fit the boat.)
15. One NEW 2-person tube (Aquaglide Spitfire Extreme Towable,
2-person 26-gauge PVC w/840D polyester cover)
16. 2 Anchors (one new and one old)
17. 6 new spark plugs with 2 spares. Compression test recently ran
on the cylinders and they are all in great shape.
18. Windshield wiper, Glove Compartment, Cup holders, Under the seat
storage, ski storage area with Teak wood grate
19. All safety equipment including air horn, distress flag, whistles,
flare gun, fire extinguisher, throw-able rescue float, etc.
20. Two white dock bumpers (fenders)
Known Issues:
1. Automatic Oil Injection system tripped the alarm. Oil Injection
system could be repaired or you could just not use the automatic
injection system, bypass the system and premix your fuel/oil 50:1.
Currently running the engine on a premix of oil/fuel.
2. Speedometer does not work. I have not attempted to fix it either.
3. Gas Gauge is not accurate. It shows full when it is full but
shows that the tank has less gas in it than it actually does. Most
likely will need a new Electric Sending Unit ($40 at ********)
4. #5 cylinder is not sparking. Mercury engine mechanic diagnosed it
to be a switch panel on the engine. Estimated cost to repair is $250
for parts and one hour of labor. Engine runs without this being
repaired, but doesn't have full power due to one of the cylinders not
firing.
Home Cookin'
i was with you until the end. Starting with $400 minimum in engine repairs on a $4,800 boat is not a good start. I would like to figure out a way to fix it first to be sure that's it.
One thing I like about buynig a used boat is all the stuff you get with it; you can save hundreds right there.
Some folks willl say they's be leery of a boat that had so much repaired, or the quality of his repairs. I say, use your judgment; if he seems to know what's he's doing, if his garage, yard, whatever looks squared away, give it a chance. You'll at least get a couple years out of it and don't have that much invested if it doesn't work out. Since this is your first boat you will likely be looking for a change after a couple years anyway.
southkogs
I'm with Home Cookin' - if I wanna' get $4,800 out of a boat, but it ain't running right, it's probably best that I spend the $400 to fix it and net $4,400 outta' the boat.
Essentially that repair makes it a $5,200 23 year old maybe fixed boat for you.
It's good lookin' though. If you want to take a look and see if your "Spidey-sense" tells you it's a good deal just be careful.
lil buggy
Burg_fisher,
i saw that one last summer/fall,
i am a cl junkie i thought it was in a different loacation though
when i was shoppin last year i was salivating on that boat as well
i cant remember but i thought it had a parts motor or something
again, i cant remember but , agreed, i thought it posted and flagged but not sure tho.
my spidey sense tells me ,,, be weary
flagging on cl could be unjust or an indicator of this or other ad failures
with the asking price and the unknown issue i would stay away
however, i give the poster a thumbs up on admission of the issue,
who knows maybe last year he did not truthfully sell the boat and TOOK IT BACK(yes another thumbs up, if thats the case)
most wouldn't
i had an 85hp merc tower of power and it ran on 5 instead of 6 cyl but all the while i was meltin everything
pisten melted and turned sideways .done.
it looks like he spent some time giving you lots of info(good sign).
fabrication of aluminum sub floor makes me nervous tho
heck if close i would go check it out.
let me know when your going,
if i can i'll go and give you an unemotional view
best of luck
ezmobee
That SeaRay is a $2k boat. Especially in that condition. Dude is trying to get out what he has into it, which just ain't gonna happen. An electrical problem with a Mercury? Yeah that's gonna cost ya!!! The boogered up rub rail on the port side would bother the heck out of me also. It could be a $4k boat if all the issues were taken care of.
Burgh_fisher
Thank you all for the opinions. Reason he was flagged was he was posting everything i posted here, it all was to long including the images. Story he told me was him and his father are into designing, restoring,building sailboats. A neighbor had passed away was the original owner of the boat kept the boat in a garage. During his fight with cancer, the wife had the boat taken out and put into the yard where it sat for 2 years. During them 2 year the boat accumulated water that sat there for a good while. Being him and his father build and restore sail boats he took on the boat and the project for his own personal boat. That when he took the floor up an area of wood and foam was bad and water filled. He took out and replaced the floor and all the bad foam, replacing it with what he states above. claims transom and everything else was very, solid and no additional work was done, other then replacing the gas tank that was not leaking, but was showing wear. Claimed to also have had it out until sept of last year when the motor issues started, what he posted was what he was informed from a marina mechanic that told him.The mechanic could order the parts that would of taken a couple of weeks to get. But he would not be able to get to the boat for anther few weeks after that. He Taken it home and winterized it. Stated he is not mechanically inclined as far as motor work, an intended on completing the work and keeping the boat, Then a change in careers over the winter, along with getting engaged. He will need to be moving out of state and can not afford to take all his boats with him, thus all the additional equipment that is included with the boat. He did say he was looking to get what he put into it in hopes of breaking even.
My gut feeling on this boat is he can be talked down substantially. He took a great deal of time explaining every detail, and i do mean every detail of the work he had done! He talked with a great deal of pride on the time and care he took. long with the details explaining why he did things the way he did.
Fully agree the price is way to high again no harm in looking as it will give me a chance of gaining more hands on experience of seeing and going over boats first hand, along with working on some firm negotiating skills and tactics, IF the boat is worth my time.
Burgh_fisher
Burg_fisher,
most wouldn't
best of luck
Thank you very much for that offer lil buggy!
May take you up on that one day. If your location is near Beaver may be very helpful as we seen a few boat in that area as well!
hostage
I would run away from that boat fast! It is way overpriced, I was looking at larger boats w/ a 4.3L that were in better condition for about $4k and they were also early 90's not late 80's. Honestly I would look for a good solid hull that has a working engine, whether it is i/o or outboard. At this price range your selection is very limited.
It is like this guy is selling a total car with a rebuilt front end. Yeah it might look good, though how well was it put back together. Another member here got a boat that had a new deck on it, though since the stringers weren't replaced and were rotted, they re-rotted the "new" deck.
Burgh_fisher
Good eye! Did not see that until u just mentioned it.. Appears it hit something pretty good.
Burgh_fisher
Ezmobee.. Being you brought that damage to my attention, i zoomed in and seems to be a crease also below the rub rail damage, along with a dinger just above the trailer wheels. Thank you again!
lil buggy
Burg_fisher,
sorry just went back thru,
this boat on the post is from my marina
not sure if its the one i am thinking of :facepalm: my memory is bad
but if so i was moored next to it
i had a lil pontoon moored in the cheap seats (500 season, no elec avail) at that time.
the guy that owned it was looking into getting a wakeboard boat with a tower
although i didnt walk around in it it looked to be in great shape full cover etc...
This one seems to be more along what we both like.
http://pittsburgh.craigslist.org/boa/2827342080.html
so to revisit that posting i'd check it out.
boat prices here will be on the incline here soon till early august
lil buggy
were loacated in ambridge,
and dock on the beaver,
absolutely love it there, the beaver river is a no wake zone:D
happy to help
just pm me
