3 hp evinrude engine does not work
boatman03
i have replaced the coils and checked to see if i hade a good spark (witch i did) but it still wont run <br /><br /> BOATMAN03
alcan
Re: 3 hp evinrude engine does not work
Hi Boatman <br />Could you give the mod# of your motor?
boatman03
mod # 106153<br />ser # 3432<br /><br />BOATMAN03
boatman03
hi i am only 11 so can you please put in simplest form so i can under stand it please <br />thanks<br /><br />BOATMAN03
alcan
Hi Boatman <br />Your 3hp evin. mod #3432 is a 1964 model. You will need to determine if you have the spark at the right time. Check to see if you crossed the spark plug wires. Did you service the fuel system? Are you getting fuel? Does it seam like its flooding?
boatman03
what does it mean to sevice the fuel line? could it be the points? are they to far apart?<br /><br />BOATMAN03
alcan
Hi Boatman<br /> Wow 11yrs old that's preaty good. I think we'll be able to get you going here. To servive fuel system, means, did you clean out the tank,carb,make adjustments,ect? Did you adjust the points? The points should be set to .020 at the widest place of opening. Was this motor running when you got it? Are you sure the plug wires are not crossed? Did you install the fly wheel correctly?
steelespike
What kind of work have you done before on outboards? The points need to be set to .020<br /> Turn to widest opening and then adjust.<br /> Most likely you need to check and clean the fuel system from tank to carb.Be very careful gas is dangerous and fumes will flow to the lowest point<br /> even down stairs or across a floor.<br />You should try to get a repair manual.If you cant afford one sometimes you can look at one at the library.There is a float and valve in the carb. that meters the gas flow kind of like the float in a toilet tank.If the system is all gunked up with dirt and old gas the gas may not even reach the carb.You really need to look at a carb exploded view to get an understanding of the way they work.any small outboard carb will do.<br /> You may be able to get it out of a manual or<br /> possibly a book at the library on carbs.<br /> or someone you know that tinkers with motors.
boatman03
i found the engine in the back of an old repair shop that went out of business and they let me keep it. (because my dad told them i like to take things apart.)<br />i had to take the flywheel off so i could replace the coils witch were wrecked and i don't know if i put it back on the right way. how can you tell?<br />BOATMAN03
boatman03
any other help will be apreaceated.<br />boatman03
JB
Ahoy, Boatman.<br /><br />You are a pretty sharp young fellow. Go to your local library and borrow a service manual that covers your engine or 1964 Johnson 3HP (they are the same engine in different color).<br /><br />There will be a section in there that explains how the fuel system works. You will need to check the carburetor to be sure it is perfectly clean inside. Also make sure that the fuel tank, the valve on the bottom, and the line to the carb are all perfectly clean so gas can get into your engine.<br /><br />Good luck, and let us know how you are doing and any more questions you still have after you get to read the manual. :)
OBJ
Hey boatman...<br />Just another note. When you replace the coils under the flywheel, there is a definite gap between the coils and flywheel. The setting is an easy thing to do and a service manual will tell you how to do it. To wide a gap and the engine may not fire. Stay with it and keep us posted.
boatman03
thanks for all your help, i will try to get a manual for my engine at the libary if i can. i used to have a parts manual but i think lost it, if you have a copy that i can buy that would be great<br />BOATMAN03
boatman03
were should i store my motor? here in mass we have some bad winters. right now it is in the basement is that ok?
JB
I think you have it in the best place, Boatman. :)
boatman03
thank you all for all your help in helping me with this engine. I will try my hardest to keep it running winter, spring ,summer and fall. Any other help i will love!<br /><br />PS: this site is the best site ever for boating
boatman03
any good names i should give mr. evinrude over here (who wont listen to me ) or should i call him my engine?
boatman03
were can i get more more parts if i have lost a part (from the dogs)
slow_boat
You should not store the engine 'upside down'...lay it on its back...controls up, prop down to allow traped water to drain out. Your dogs can be an expensive asset. Seems as every one 'I' have bought parts from for my old motors seem to be quite fond of what they are selling me...and is painfully reflected in the prices they charge.<br /><br />Keep the dogs 'at bay' from your parts...no pun intended :)
